Thanks for your comparison neBstress
I am waiting for mine to see how it feels in the hand ! Well and when operated
Did you bought from GB or directly to Simon?
Just asking because mine is quite delayed, eventually stuck in chinese post offices or something alike :person_facepalming:
I bought mine from GB, they had an offer on it at $9.99 and I added it to other items I was ordering, I was lucky it arrived in just under two weeks.
It is a nice size in my hand, I don’t have the biggest hands, about average I’d say
The mode memory seems a bit weird, it turns on one mode ahead of the last mode used. eg; turn off while on Medium and it will turn back on on High, turn off on High and it will turn back on on Low, etc.
Hum, that explains why it was faster ! Glad your arrived !!
Well, that UI with memory…will not be my favourite. I expect to mod it and put another driver and eventually LED. It seems a nice flashlight, but will need some “touch” to be nicer
Thanks for taking time to do the photos and upload them I guess it is a 17mm driver that is in there, so it can “easily” be replaced by another 17mm driver, such the ones used in the bigger Convoys S2+ (and others) with Biscotti firmware. However, due to the chemistry of the batteries, using such a driver (or any from MTN Electronics, Lexel, or led4power) will make you lose the compatibility with AA batteries.
If you want to explore it only with 14500s, you can choose any of the above options or others, I’m just referring to the ones that people used the most and whose quality is good.
I am not sure yet if I will use a single emitter or if I’ll try to make a triple. Probably the first option, with a Luxeon V and a led4power driver, using 14500 batteries!
When I get it and when I mod it, I’ll post it, but it may take a while…for both
Meanwhile, venture yourself in of the mods, we all start somewhere :+1:
Thanks again!1
