phantom23
(phantom23)
12659
That would actually be a great option for most of your lights, I hope you can make them available.
lg.tech
(lg.tech)
12660
Love the look on those. One of them is going to be my first real thrower. Can’t wait.
ch1ir
(ch1ir)
12661
Where and when will this be available?
Simon_Mao
(Simon Mao)
12663
the tail spring in the M21H or M26D can not bear 16A current , i should solver this problem first
Simon_Mao
(Simon Mao)
12665
first one is a sample ,the second one (copper pill) is in stock now
Simon I could put a bypass wire on the spring so it could handle more amps. I’m happy to do that myself.
Would that make you happy to supply m21H with 6V 8A driver?
Will there be a 4000k ish version?
Is it too early to ask?
Funzel67
(Funzel67)
12668
Hi Simon!
Please consider to ramp up from moonlight so that we do not need always to start with memorized level!!!
Would be a massive step up in usability!
Sirstinky
(Sirstinky)
12669
It could be bypassed with a copper braid. If thats not possible (like press-fit spring) you could retrofit a PCB with a bypased spring?
Now this is what I’ve been waiting for. I take it this is what we had previously requested for, which is a dual fuel AA/14500 T3 with an S6 head?
Mandrake50
(Mandrake50)
12671
Ok. That makes sense. Thank You!
merlot
(merlot)
12672
This looks great. I’d love an aluminium version with a 719a 2A driver (I’m happy to build this as long as the host is available).
MCDU
12673
Now we just need S21G TiCu
Yes, perfect! That’s what I was hoping to build, just with a green light/tube to go with a green Osram.
Those look excellent.
I notice it has a cut out for a USB-C charging port. Please make sure the driver can charge with a USB-C to USB-C cable! The 4x18a SBT90.2 and the M21F GTFC40 both can charge with a USB-C to USB-C cable which makes them very easy to charge with a phone charger. Unfortunately, my M3-C GTFC40 requires a USB-A to USB-C cable, which phone chargers don’t use anymore. It’s hard to charge that light now.
Simon_Mao
(Simon Mao)
12677
I have no plans for this at the moment, due to size restrictions, I’m not sure if the current can be raised to 8amps.
Simon_Mao
(Simon Mao)
12678
I tend to use double springs.
