【convoy】
It would be great if you also add it to your AliExpress store.
It looks like the Manta Ray has the exact same 22mm 6V 8A boost driver, and it uses a spring.
Hi @Simon_Mao a quick question:
Would you also consider an orange peel version? So there’s the tail switch versions (T3&T5) and side switch versions
I’ve recently modded my T5 with LML2AW.DC (【convoy】M21F MAO on sale - #12450 by SilicaGel), the stock driver in T5 is indeed underpowered, but the same applies to 519A as well. A 5A driver makes these hosts much more fun regardless of emitter!
@Simon_Mao
If anyhow possible, such a spring would be fantastic!
I would upgrade all my lights immediately.
i got CREE XFL05K , sample
I’m going to design a new flashlight for it, using a 35mm TIR, 2 x 21700 batteries in series, but the batteries are placed side by side.
27 Thanks
Is that LED dome extra tall, or is that just a trick of the camera angle?
I dont have flat-top F12, sorry
Thanks, Simon! Would you also add the B35AM option for the H4 with battery?
Thank you Simon!
This sounds perfect!
With two 21700, it will be little bigger, so why not use the 50mm TIR?
modded my L21b with SFT40 2700K 95CRI and it’s definitely nicer than the 3000K version :+1:
8 Thanks
Reminds me of good old mt-g2…
However, the individual light segments are arranged more densely in the MT-G2, which should significantly improve the beam. On the other hand, the segments of the XF-L should also radiate laterally, which could reduce the effects on the beam.
I could imagine that these XF-L are basically just several XD16 chips under a silcon dome with one substrate. Cheap and relatively simple since no new LED chip is necessary.
Nope, absolutely not. Unfortunately.
There was no solution after some weeks, but only the repeated answers that some drivers use Attiny MCU (yeah, I know this, thank you). I never got the right drivers or a refund. And there was no answer from him after my last post either, despite he answered to other stuff here.
I now test the Aliexpress refund option for first time . I already got a free shipping label, and sending back is really comfortable from Germany since I just send it via German shipping company to German address and drop the package at my nearest gas station which is also some sort of post office :smiley:
I had never thought, that I have to test Aliexpress free return in Simons shop. And I ordered a lot via Ali in the last years, I never had any problem. This does not help in gaining trust, that’s for sure.
Holy Moses That’s going to really need a TIR to keep the beam clean! I wonder what the output is?
By the datasheet, it looks like it is an oversized dome, with the sides slightly cut off.
@Simon_Mao Could you please answer a couple questions?
  1. Any plans to make a 20mm 6V 5A boost driver?
  2. How about making a brass driver ring for S2+ with a larger inner diameter to fit a 17mm 6V 4A boost driver with XHP50.3?
@Simon_Mao
Can you an a Forward Clicky Option to your lights. (or by request)!
H4 B35AM with battery
