Simon_Mao
(Simon Mao)
1621
sorry ,i only found 6500k 4000k 3000k
Simon_Mao
(Simon Mao)
1622
yes ,and what driver model?
Satan
(Satan@103TFS)
1623
Simon when will the slightly bigger inner-diameter of your 21700 available ?
Mocarny
(Mocarny)
1624
It could be in driver for SST40 and new 3*SST20
If turbo is only 1-2 min I can’t see point of memorizing it, and it would give more modes, 4 in loop and turbo when needed. Then it could be really “turbo”, not the highest mode
Yokiamy
(Yokiamy)
1625
Simon, is there an easy method to change or disable the temperature regulation of the L21a SST40 driver (i have the version with 4 modes only) ?
Maybe by disassembling the temperature controller, or soldering a bypass resistor, or just bypassing it with a wire?
Simon_Mao
(Simon Mao)
1626
i’m not sure ,which mode do you need? i will leave you a message when it’s ready
Simon_Mao
(Simon Mao)
1627
i have a driver sample ,0.1–3–30%,double click turbo
Simon, that mode spacing sounds good to me for the XHP35.
Mocarny
(Mocarny)
1629
There can be even 4 modes, but 3 are ok too. But 2 click turbo should be from any state, on or off, and long press for low is really great and handy, no need to cycle through all this bright levels. Good reading light is about 20-25 lm in warm white or NW, in CW little less (for me), so if it is an EDC light (in my opinion 3*sst20) there should be mode to have this 25 lm. 40 lm is too much for me, M3 has ~ 40 lm on 1% and it is too bright for reading, but good enough for walking. But M3 isn’t EDC reading light, I guess, so it is ok
Will it be diffuser for 3*sst20?
Yokiamy
(Yokiamy)
1630
Simon, any ideas about this ?
Simon_Mao
(Simon Mao)
1631
uh ,it’s for reverse switch ,it only works when flashlight is on .
In the future, I can design a diffuser for 3*SST20 flashlight
Simon_Mao
(Simon Mao)
1632
i didnt get reply from manufacturer,yet.
i will reply you later
Yokiamy
(Yokiamy)
1633
Thank you, looking forward to it !
hodor
(hodor)
1634
Anyone tried the SST40 in DA tint yet?
KevinZA1988
(KevinZA1988)
1635
Still waiting for my 5000K DA from Simon and 5000K DD from Kaidomain to be delivered.
hodor
(hodor)
1636
Ooo will be interesting to see how those compare
KevinZA1988
(KevinZA1988)
1637
Yeah I’m quietly optimistic… I hope that they will be a lot better than the “regular stuff” they have always sold in the past.
Hi Simon, did you overread my question?
Simon_Mao
(Simon Mao)
1640
17mm is too small ,friend
