This one?
Simon: I am interested in how you know the heat resistance of LG UV LED is not good. Any real data or just reports from users? And what does not good mean? Lifetime shortened to 2000 hours is still better than most conventional UV bulbs.
Well, thats a SST40 driver, the M3 has a XHP70.2
This is the M3 driver
Maybe it’s under the… thing I don’t know a name for. Big grey square thing.
That would be the inductor.
What’s below that looks like a foam sticker or so.
On my sst40 driver it was a small black smt component without print.
I think it’s the small component near the chip on the left.
Maybe you can post some detail photos?
Maybe this helps
I’ve only got the S11 XHP50.2 driver, but I’m happy to desolder the inductor to show people what it looks like, in case it helps.
How about to the UK? Possible to save on postage costs by shipping batteries inside flashlights?
Not necessary, posting detailed (macro) photos will do.
Removing the blueish foamy thing, might help though.
Here we go - not the best macro shots in the world, but a quick one while I have a few moment being left alone :stuck_out_tongue_winking_eye: I know it’s not the M3 driver, and they actually look quite a bit different, so it’s probably useless for what you’re after.
my guess would be this one
can you try to measure resistance?
also, try to measure with different temperatures,to verify.
Thank you very much for your explanation. If I design the 21700 version of the P60, I want to make integrated head or brass drop-in for it instead of D26 ,
This structure of D26, I think it is not good for heat dissipation
Sorry, I am not specific enough. I am not based on the data, but based on the after-sales situation of the S2 LG UV flashlight.So I need to do more testing.
Okay, current room temp is 8.8k Ω. Unsure of what the temp is in here now, probably 22-23C.
Breathe hot across it and it drops to 6.something k Ω. Slowly rises, then when I blow cool air on it, it rises much faster. That’s the one.
Many battery shipping delivery way to UK ,
it’s cheapest to insert the battery in the flashilght via epacket. 7-20days
there is a special battery delivery line to UK ,almost the same price as epacket ,just a little expensive, battery can be shipped seperately via this line,delivery time 5-10days,
i recommend this
Time for my silly question. What is an integrated head and would it still allow drop-ins to be used?
Yup, would replace most of mine as well. I pack a small box with a couple of dropins, extra cell and keep them in the car for road side work. I also love the flexibility of the P60 droping, can make about anything quickly.
Some people are still using D26 drop-ins despite the non ideal thermal path but they would like to use their drop-ins with a host having more versatility towards batteries size (better capacity of 21700). Making your own diameter will defeat this. Those people won’t buy your host if it won’t have D26 compatibility.
Simon, yes the draw is being able to use the existing form factor of the dropin. There are a couple of new dropins on the market that have a more substantial brass pill and a tiny bit of copper or aluminum wrap draws heat out well.
For example, these are great to work with and manage heat much better than the old style dropin…
http://kaidomain.com/Flashlight-DIY-and-Tools/led-drop-in/KDLITKER-P6-LED-Drop-in/KDLITKER-P6-SST20-Luminus-SST-20-700-Lumens-3V-9V-P60-Drop-in
I have modded several of them now and really like them.
The Convoy 17mm driver for SST40 ,4 modes 0.1–3–30–100, 5000mA with a substantial brass pill would be top of my list with SST40 or 3v XHP50.2.
Add an R020 in parallel with the R010 and it’ll bump it to 7.5A :wink:
