1 degree TIR… glad I didn’t pull the trigger on the M21H yet, I wanna see what this sucker will do with SFT-25R!
Edit: “flashlight sample with 56mm TIR 1degree , SFT-25R , 8A driver”
I need it. What host was that? Or is that the new side-switch L21B?
M21K with 3X21D head design?
3x21D’s head is much larger.
What LED is this?
Apparently those 1 degree lens were designed for either SFT-25R or LMP Q5 so probably one of them.
Wait, wasn’t it M21K?
Yes, it’s specifically for the 14500 format. I wondered if the height and diameter information had been published
Definitely not, M21K is shorter. It’s also too small just 5mm outer diameter meanwhile new lens are 56mm.
@bugme143 , @MineHack7488 , @mcjtom
Sorry I didn’t specify this earlier:
Might collect a bit more light than the Z1 does, but I’m curious how the two will compare with the same emitter. I’d be more excited if the 1 degree tir works with an SFT-42R / F45R. I think the Thermals in a light like that one shown above will outperform the Z1.
The new light will beat the hell out of the Z1 in both output and throw.
On throw mode the Z1 only collects half of the LED’s emission, while a TIR can collect 100%. The Z1 has a 40mm lens against a 56mm TIR, which should almost double the intensity. The Z1 throws a hair under the M21A/C8, while the 56mm TIR rivals the L21B reflector.
Don’t suppose you know the general size of the host? If it’s M21H size I’ll hold off, but if it’s different I may buy one of each.
I don’t. But it got to be bigger than M21K.
M21H uses 35mm lens, M21K - 50mm and those new lens are 56mm. That’s around L21B when it comes to size.
Huh, basically the same as the IF22A. I thought it was a 40mm but I must be getting that confused with something else.
Dope, thanks. Gonna hold off and wait for the drop, then!
Upcoming e-switch L21 variant maybe?
Yup, I’m pretty sure you can use IF22A lens in the M21H.
With TIR lens inside? I doubt it, it looks different than Simon’s render of the L21C.
this convoy , size like … skilhunt h200 )))) or another L form fleshligt 18650
