【convoy】
@Simon_Mao:
Please add flashing pads.
or better flashing via USB
whats the point of allegedly having an open source firmware if we cant access it?
11 Thanks
@Simon_Mao Please add flashing pads! Software customization fits perfectly into your open-design philosophy :raising_hands:
10 Thanks
Schrödingers firmware
As long as it can’t be Flashed its Open source and Aduril and not open source at the same time.
Also Anduril is GPLv3
The Key idea
“is It guarantees end-users the freedom to run, study, share, and modify software”
Copyleft Requirement: If you distribute a modified or derivative version of GPLv3 software, you must license the entire modified work under the GPLv3 and provide or offer access to the complete corresponding source code.
so as long as @Simon_Mao is distributing the whole complete corresponding source code under GPLv3 and he might be legally ok.
But the key “spirit” of GPL is to give the user Freedom to modify and run there Owen version
@Simon_Mao It would be nice if the driver used a more modern MCU like AVR32DD20.
And flashing pads, of course.
6 Thanks
Not a word of thanks for implementing Anduril 2.
No, just ‘we want more.’
@Simon_Mao Thank you Simon for this Anduril2 driver!
So it is this one: grafik ?
15 Thanks
Honoring licenses of a project developed in 100% free time for free is not “more” but the bare minimum.
I am very excited about this driver, but the source code needs to be published.
No, the 10A buck driver currently available for purchase has been out for about a month now, and its description is also on the site. Among other things, the ridiculous 10-click lockout mode is what has kept me from buying it so far. I’m really looking forward to the Anduril version; Simon mentioned on Facebook that it’s coming in a month.
6 Thanks
No word of thanks for the Anduril Devs whoes free software he is selling in his commercial product?
All they asked for is:
GPL is “free as in freedom, not free as in free beer”
How much less brighter will the LHP531/LHP73b be in their 90CRI versions?
I was just wondering, recently I bought some Great Value bulbs 3000K CRI > 80, and I see a lot of difference compared to the 70CRI bulbs, but when I compared the CRI > 80 to an Incandescent 3000k I see a difference but not as big as the first comparison.
So another question, how much less brighter would be a 80CRI LHP531/LHP73b with good tint compared to the 70CRI?
The NV1010 5500K 70CRI and 4000K 95CRI were compared here, though in different hosts. The 4000K 95CRI has -35% fewer lumens due to a combination of
  • Higher CRI
  • Lower CCT
  • TIR being less efficient than reflector.
If one were to isolate the effect of CRI only, my guess would be -25% to -30% lumens for the higher CRI, everything else being identical.
A linear interpolation between 70CRI and 95CRI is probably ok for a ballpark guess, assuming that the intermediate CRI is achieved by mixing phosphor from the two extreme variants.
But in practice I don’t see a place for 80CRI emitters–the efficacy difference between 70CRI and 95CRI is small enough to make it sensible to go all-in on efficacy or CRI. Though one can achieve intermediate CRI in multi-emitter lights by mixing.
Update to the above: I digitized (using the tool by @SyntheticSol) the spectra of a NV1010 and LHP73B at 4000K, to compute their spectral efficacy. I got 346lm/W from the LHP73B, and less than 265lm/W from NV1010 4000K R95. “Less than” because part of the red tail is cut off by the spectrogram.
Thus the loss in spectral efficacy (lumens per watt of emitted light) is at least 1-265/346=23.4%. Combined with the assumption that high CRI phosphors are also less efficient than low-CRI phosphors, the above estimate of 25%-30% loss in output is reasonable, possibly closer to 30%.
From those numbers, one could almost assume 1% lumen loss per each % point higher cri, given everything else is the same, ie cct and emitter make/model.
At least it would be a quick and dirty solution.
Nice find! The relation “-1% lumens for every +1% CRI” is quite an elegant heuristic. Important to point out that this is not equivalent to per +1 CRI point; both quantities vary multiplicatively. This probably breaks down for emitters that are not white LEDs, but should hold approximately for white LEDs of decent (say 60+) CRI, without extreme tint deviation (which can change spectral efficacy while preserving CRI) or extremely high/low CCT.
I wonder if a similar approximation holds for CCT, though it would be highly nonlinear.
I wish I had a decent way to measure lumens.
My current method involves “does this one hurt my eyes when I shine it at the wall”
:grinning_face:
8 Thanks
I use a single framed piece of paper to measure lumens. This method was developed after a conversation with @Dc38 in which they proposed diffusion as an alternative to integration, for the purpose of uniformizing the beam. It’s much simpler to build/use than an integrating shoebox, and more precise too.
“How much it hurts the eyes” is a good heuristic for lights with similar beam profile, but between lights with the same output, a thrower will hurt way more than a flooder. Literally bounding the light off the ceiling mitigates this somewhat, though the readings slightly favor throwier lights.
@Simon_Mao 14500 headlamp available this year or looking more likely next year?
Just received 2 M21Ks, along with the 10 and 30 deg beaded optics, so now I have 3, all in 4000K:
  1. Black with low CRI LHP73B
  2. Sand with hiCRI NV1010
  3. Silver with F150R
Main takeaways:
  1. This F150R is so yellow in the default 3deg clear TIR :frowning: , gets a bit better with the 10 deg beaded, not sure about the impact on throw, no idea how to measure it without devices, though the spot doesn’t get much bigger while becoming much cleaner with less artifacts etc (was a bit ringy at close range)
  2. The LH73B is nicely neutral and gets somewhat more rosy with the 10deg, similar impact to beam as with the F150R
  3. The NV1010 is nice and rosy, didn’t try it with the clear optics, with both beaded tint is pretty much the same, just a bit smaller spot with the 10deg (well duh), though not that big of a difference
I’m thinking of keeping the 10deg on the F150R, despite it being throw focused, just for the better tint. I’ll give it a try outside at night to see if it’s as egregious as during the day on a whitish wall, maybe it’ll be ok in actual use, but I’m heavily considering keeping it with the beaded 10deg
NV1010 5000K High CRI with the beaded lens is so nice!
Looks like afternoon sunlight
I will use that combination for my new aquarium spot lighting
Not sure if I have the 10 or 24° on right now since I didn’t know that I ordered two different ones but it’s quite floody.
Very nice :+1:
Edit: I used the 24° initially, but I will use the 10° one. Far from being a thrower, spot about half as big as 24° (go figure) and I might say probably a perfectly usable size for short to mid-distance.
Anduril 2.0 buck driver for 21X3 would be awesome… but S21E is also a good start.
This is possibly off topic for the thread, but can you show off what you’re working on or give some links to similar devices elsewhere? Seems tricky to get these TIRs held in place and do the heatsinking necessary… and it sounds interesting.
