First issue is how can I make the lens red so it acts like a back up rear light. I have a pretty good rear light anyway but this can be used as a solid light whilst the other flashes. The lens needs to be red.
How do I go about getting a red lens or is there another way??
Maybe find something that’s transparent and red to stick over the head of the light. I’ve seen people go as far as using scotch tape and a red marker. I would suggest this but you’ll also need a driver that won’t exceed 2.2 amps.
IMO you should look for something that diffuses the light. perhaps a cone, kinda like the Nitecore LA10. My reasoning behind this is so you can be visible from the side as well.
That’s a good suggestion. I have the cone filter thing for the s2+ just looks a bit odd. It’s also pretty thick so diffuses to much light. It means I will have to run the s2 at a higher power.
Thanks. Will look into that. Any other suggestions. The side viewing on a bikey light is important. If the above came with red sides like the front that would be perfect.
I can see 200Ω resistors on each side, presumably in series with some sort of led (5730s?). That means driving current oscillates between slightly below 50mA at 12V, and somewhat above 100mA at 24V. A good compromise.
Could be easily modified for use with a li-ion by removing the resistors and driving the leds in parallel with a simple 350mA driver, like this one: 350mA 1-Mode LED Flashlight Driver Circuit Board
It must be noted that 5730s are rated for up to 150mA continuous (≈0'5W), so they may get a bit toasty on those limited cooling ability enclosures. This is all conjecture, though.
