Copper is a state of mind,
. I guess I have a Copper Attitude right now. This build is going to test my patience, as I have not a clue as to, how or if it will work out. I usually have it already planned out, but I just can't see the finish line here... yet.
Here's a teaser, with the major components labeled.
Here's a teaser, with the major components labeled. Good luck on figuring it out!
I will be back when I know something!
08-21-2012
So, I have decided to do this as a rechargeable light, with a charging port. It's a lot easier for me, to do it that way.
I have gotten a little (very little), done on the head and here's the photos:
Judco Switch
Charging port
Inside view
I had to use a piece of 1" pipe, inside the 1" coupling, to make a tight ring for the P-60 drop in.
I will have to do some fine tuning to get the reflector in, but it will be tight.
Next up is making the copper heat sink, to hold the pill and touch the sides of the head.
Does anyone have a 28mm glass lens?? Anyone? I need one, or I have to make a plastic one again. 28mm, 27mm, or 26.5mm would work
Did some soldering and working on the wires today. Not much time, gotta go.
The replacement light build is now showing in post #42-43.
