CR123 version LD30 driver with moonlight mode,no pwm
Diameter: 17MM
Input voltage:1-3.2V
Output voltage:
High 1000mA —-> Mid 300mA —-> Low 6mA (if the voltage is 1.5-3.2V)
High 500mA —-> Mid 150mA —-> Low 6mA (if the voltage is 1.0-1.5V)
This driver is suitable for CR123 battery,no PWM
Nice!!!
This should also work with 2xAA batteries (as long as the host can handle a 17mm driver)
yes ,right
What is the thickness of it, with and without the spring?
and works on 1*AA as well!!! interesting..
any plans on making this driver smaller? like 15mm or even smaller?
Two layer if 15mm
with spring 12mm
without spring 7.8mm
appears to be very close to this old driver with different slightly different mode spacing
price appears slightly lower than at CNQ or BG
