This one is fresh from the press and has a 6mm round die. No, it is not going to throw, no, it will not be the most efficient led, the surface will probably not be uniform in brightness, the maximum output (1150lm@1A) is pathetic for such a big emitting area, etc. etc. But it does come in a 9V version, making it theoretically possible to fit into a flashlight with 3xli-ion in series. So, to stop for once the discussion of putting COB arrays into a flashlight: who is going to build one :-)
But the image of the die from an MTG2 is unattractive, as is an XML, or XPG. A round die at 3000 Kelvin is much nicer. It’s an entirely different approach, instead of a blast of uncontrolled lighting up everything, it is a precise tuned beam of light. If it all works…
Anyone have an image of what the array pattern looks like when on? Certainly starting off with a round arrangement, even if it’s like an Mt-g2 in terms of pattern should be interesting in a projector style light. Throw it slightly out of focus and you could have a nice beam.
The Winnie-S is used with the CXA-1304 to light paintings, pretty tight hot spot with very little spill. The CXB-1304 is the same size and shape but more efficient.
I have successfully swapped inerds with 2 D MagLights such that I now have a free 3D light to play with. It was using 3 D size NiMH cells to run a de-domed XM-L2, but now that set-up is in a 2D Mag with a dummy cell on a 32650.
The usefulness will depend on how uniform the brightness is over the die area. If not, a MT-G2 will be better in all aspects. Philips claims a very uniform brightness for its 'crisp white' COBs (but that runs at 34V ).
The Cree datasheet shows a full line, including an 80 CRI 5000K version. (maybe 90 as well, not sure) It’s just new and not readily available at this point. Will keep an eye on that for sure.
In the meantime, I don’t mind a warm tint in the old MagLight, keeping with it’s tradition.
I tried it on a Jax Z1, very ugly projection. It does make decent output and Vf is close to 11V at 1.5A if I can remember correctly. Heat will limit the output on this one, bad.
They don't say anything about improved uniformity, so why would the projection of the CXB be better than the CXA? Do you have a picture of the die projection of the CXA?
Its definately not a flashlight cob chip, not at all
In real life( at least batch 02) performs like 20% better than CXA, and its designed mostly for general lighting and spotlights lighting aplications, probaly retrofits too
Has a GREAT CRI, fairly okay thermal resistance and terrible max load vs temperature perfornace( exacly like CXA) - yet another reason why it cant be used properly in a flashlight, even a flooder
With a proper reflector this one and especialy his bigger brothers 1507-1512 can be used in automobile lights
can be achieved a very nice ribbon-like beam pattern
P.S
They still “hide” real R9 though….even at CRI 95+ binned matrix chips( real one 97) the R9 is like 80 or something( usualy less)
