Looks like another one to have.
Well, it is underdriven at 1100lm, but the host is interesting, do we know it already?
It says MT-G, not MT-G2.
Well I figured this one would have quite a bit of spill judging by the size of the led.
It is an MT-G2 by the pictures. It also says current output 3000ma, which would give around 2000 lumens so it’s a bit confusing.
What I’m most interested in is how the circuit runs from a single 18650. It must be a boost driver, so it’ll be interesting to see how much current it can get to the LED.
Host looks like an HD2010, and I am interested in the driver. The 3A may be tail current, which would explain the 1100 lumens a bit better.
Says 3 amp output current… that would be over 6 amps from the battery. Also says 5000K is warm white. With all those bogospecs, I’d pass on it.
Yup, somewhere between the manufacturer and KD, they have no clue what this light is.
Well, I suppose it could be interesting with an MNKE/King Kong IMR and a proper driver…
Has anyone ever tried an Mt-G? I had never heard of it until we all went MT-G2 crazy. They only cost about $8.
The multi-die setup tends to make the beam messy. Not the best for flashlights. I thought of getting one just to try though. FYI, it fits on an MT-G2 star.
Agreed on both fronts. After looking at an MT-G, that light is most definitely using an MT-G2 emitter.
But…can you believe that picture? It is after all, just a picture. Who knows where they got it.
May be bait and switch, sending us a MT-G and arguing that the specs said MT-G. 0:)
I’m amazed that a single cell can run an MTG2 at all, I thought it needed 6 volts to run good
I think something like this would work better inside that: http://intl-outdoor.com/boostbuck-318v-triple-xml-circuit-board-p-542.html
I tried that driver on a singke cell… no go. Kept thinking it was in low batt. Had to mod light for 2S.
I agree with relic38 that this driver needs at least 2 batteries in series to operate correctly with an MTG-2. One 26650 is still not enough battery.
Hi,
I’ve emailed them asking about this, via their “Contact Us” page, and will post here if they do respond…
