Cree U7 - Disable strobe function
Hi. I have motorcycle LED auxiliary lights but they have the three functions including the strobe which I need to disable.
Does anyone here know how to disable it. There is a UCI with markings either 76CNI or 76CN1
Sorry the IC should be IC2.
I found that you have to use relay to connect chip pin in to ground because memory is written in IC1. You have to connect twice power supply to set memory to strobo mode. Then check that if you connect pin 3 (without power) to grount the circuit forgots state and set it to 100% mode instead of strobo mode. If it works you have to use NC relay to reset memory of IC1 to ground. When the power is on you have to disconnect pin 3 from GND. Sorry for my bad english but I wanted to share my solution of this problem :slight_smile:
