If you’re okay with a 20mm or 22mm driver, you can get a Cu washer that’s 24mm in diameter, and use a step-bit to drill out, say, if it’s in 1mm steps, a 19mm hole and only go partway through with the 20mm step. Then solder the 20mm driver into the hole so that the spring is “up” when you drop it on the shelf.
