I am pretty much completely ignorant about led lights….
I bought this light. “UniqueFire HS-802 Cree XR-E R2-WC 2-Mode 230-Lumen” a few months ago from DX. I like everything about it. And would like to find something like it only cheaper. Is that impossible?
I especially like that it throws a narrow long beam. I have a farm and sometimes look for black cows on black nights during calving time. And having something that shines that far is real beneficial. Also I can see what kind of critters are wandering around the house…
I guess what I am asking is what makes it what it is? HS802? Cree? 230 lumen? I don’t have a clue.
That's actually a very nice thrower you have there; I bought one for my brother-in-law for Christmas a few years back and he still likes that light. I made a couple of changes: I replaced the tailswitch to make it a single-mode light (low need for low on a dedicated thrower like this) and I replaced the emitter (as the original had broken off the board due to a fall on concrete).
Thanks for the suggestions.
You are right about not needing a low setting on this light, I usually want full blast!
I didn’t know these kind of lights existed at an affordable price until I found this forum a few months ago.
Since then I have aqquired 4 or 5 led lights and don’t know how I got along with out them.
I bought a real cheap one off Amazon that has adjustable focus and actually throws a rectangular beam when zoomed out.
UniqueFire - the brand/manufacturer of the light host
HS-802 - The model name of that particular UltraFire flashlight
Cree - The maker of the LED emitter inside your new light
XR-E - is the model of Cree emitter that is used in your light
R2 - is the particular bin designation of the emitter. The R2 is considered to have the highest output of the XR-E bins
WC - is the tint designation. This one is White Cold. There is also WW (White Warm) and WN (White Neutral). They are based on the emitters chromaticity.
2-mode - means that the driver has two output levels. Usually a high and a low.
230 lumens is the claimed output level of the light's brightness.
Heading over to the Flashlight Wiki and reading up there will answer many of your questions. ;)
You’ll really like the Jacob A60, I have the original it was copied from and love it…that would be the Solarforce M8 (which might actually be a copy itself, don’t know)
The form factor of this light is great, the reflector really throws a tight beam and a surprising distance. For your purpose (black cows) a blue-white light (considered to be cold or cool, orange like a fire is warm) is good as it can help you see that black body. Black is a difficult color to spot from a distance, white of course is one of the easiest. (black absorbs the light, white reflects it)
Enjoy the urge to collect, with all this newfound knowledge you’re gaining! It’s quite an addiction…I have some 27 lights now, some here have well over 100!
It’s because no one is more clever or more stupid than any other here.
Good buy, I hope you like it. I think gords made a direct drive mod tutorial, in case you need more output out of it
Get a nylon head gear, they make on with multiple attachments to hold various lights. Wear the light on your head and it points where your’e looking. Cut all the wood you want! I love my Stihl!
The HS-802 is about as good as it gets when it comes to ultra long distance narrow beam throwers.
But if you want a wider beam more suitable for scanning fields without needing binoculars, an XM-L C8 light may better serve you. I find effectively it throws just about as far but with a wider beam and more flood so it makes for a very good general purpose light. The best out of all of them definitely has to be the Xin TD C8. It also has the newer XM-L2 led which is the latest and greatest of the Cree emitters and can put out close to 1000 lumens vs the 250 or so of the XR-E in the HS-802.
I ordered a Jacobs a60 and a couple of other lights from aurabuys the other day and it shows they are shipped. It shows from 7 to 30 days. That is a lot of leeway… It is not that I have an emergency need of them, so no big deal.
Are their reviews on these lights for real? Or just make believe. I bought them because of what I read on budget lights…
