Crelant 7G2cs XM-L U3 ( Thanks Pulsar ) Review...
Got this in the mail from Pulsar yesterday. If your into EDC’s with excellent throw? You’ll definately want to check out the Crelant 7G2cs. It has a rear clicky along with a forward clicky. For the record, I love forward clickies! I couldn’t help but notice the resemblance to my Solarforce L2T ( Apart from the larger head )
The larger head allowing for a deeper reflector gives this little light very respectable throw for it’s size. POA is the small gray satellite just above center of the pic.
Crelant 7G2cs U3 658 lumen ( Xtar 18650 )
Solarforce L2T w/ Solarforce single stage 880 lumen drop in ( Xtar !8650 )
As you can see from the pics. The L2T has a bit more flood. But even with the higher lumens it can’t compete with the throw of the Crelant. The depth of the reflector of the Crelant gives it a nice advantage over the SF. I’m beginning to see why Gords doesn’t like P60 lights.
All in all a awesome little light. The barrel isn’t picky about what batteries you feed it. It tail stands & overall a very nice looking light.
Features
Specially designed for Military, Law Enforcement, Self defense, Hunting,
Search& Rescue and Outdoorsman
Tactical-on side switch Infinite brightness adjustment
Stainless steel retaining ring on the bezel protects the head from drops and impacts.
CREE XM-L LED
Max output of up to 658 lumens with an effective range of 300 meters
New hybrid reflector specially designed for the CREE LED, allows for better beam quality,efficiency and throw capability
Newly designed high efficiency broad voltage drive circuit
IPX-8 standard waterproof
change brightness by continually pressing on the side cap button until the desired 100% to 1% to 100%,and stop when you got desired brightness
Flicker at 3V indicates low voltage. Power cut off at 2.75V
Specifications
CREE XM-L U3 bin LED with 50 000 hour life span.
Maximum output: 658 lumen
High efficient constant current circuit and output-luminance
Microcontroller drive circuit
Tactical High Mode, and On side switch Infinitely variable brightness system
Hidden Strobe and SOS, Quickly click 2 times side switch —> Strobe , and quickly click 2 times again —-> SOS
Working voltage: 2.7VDC - 8.5 VDC
Battery Types Supported: 1 x 18650 or 2 X CR123A
Runtime High output at 2.5A: 658 lumen max for 132 minutes. Low output at 0.01A: 5 lumen max for 39 hours
Mil. Spec. Type III hard anodized aircraft grade 6063-T6 aluminum alloy
Color: BLACK
Ergonomic grip with anti-roll design
Candle function with ability to stand on tail cap
Tactical forward tail cap switch
Bezel: stainless steel
High performance aluminum smooth reflector with concentrated beam shot
Waterproof: IPX-8 Standard
Lens: Toughened ultra-clear coated and anti-abrasion glass
Dimensions: Length 150mm, Head Diameter 35mm
Weight: 133g excluding battery
Accessories: Lanyard, spare o-ring,
Nice review Dale. Light looks great.
its a great little light. just needed funds for other things... will probably end up with another one, or at least another crelant lol
Try out the V9CS, or the 7G6CS next.
7g6cs is on my radar
I really like it as well.
hmmm, nice review, you only found one reason I dislike p60’s though? lmao
+1 I think if the head was configured differently on them. They would prolly be more efficient.
