Yesterday a package from I.O. arrived, a lot of goodies and all the parts needed to complete the 7G5 upgrade:
The 3,5A driver, a new U3 1C emitter, some shims and o-rings, thermal paste.
I'm used to the Nanjg drivers, but this one with the two boards and the big inductance coil is definitely a big one!
It's immediately clear that the driver cannot just go in the same place the old one was, it's too high. But I got a plan.
The stock driver was seated on the upper lip of a big brass pill, which in turn was pressed in the alu flashlight body. The brass pill is 10mm high, the seat in the head for the pill is 14,8mm deep. The new driver, after removing the large secondary board (it's only for the + side spring) is 14,5mm high.
Now if I shorten the brass pill and cut a new lip in it to seat the new driver much lower than stock, it should fit just right.
After some careful working with the faithfull Dremel, the brass pill is cutted 5mm high, and a new lip cutted on the inside to seat the new 19mm diameter board.
The pics show the stock pill and after the shortening. Note the relieved inner lip. That was the hardest to do with just a handheld Dremel, but the fit of the new driver board is perfect.
Pressing the new modded pill back in the head was easy, with help of a 1/2" socket and a soft hammer.
It's not clearly visible, but note in the black wire hole how close the coil is to the emitter mounting plate
The nice touch is that the brass pill still looks perfectly stock from outside, with the original Crelant spring plate.
Then the new XM-L U3 1C emitter is installed and perfectly centered thanks to the stock plastic centering holder.
The rest of the reassembly is pretty straightforward.
I like the 7G5 in the shortest configuration available, with 2x IMR18490.
The only complaint (my fault) is some dust particles found their way to the reflector. Will try to clean with a compressed air can (for electronic cleaning) but the can is empty, have to buy a new one. Ok, no big deal.
Time to hit the switch: Geez, it works! was a bit scared, I admit it...
Driver is great, the 3 modes are perfectly spaced, low is actually lower than the well known Nanjg105, med is bright and very usefull, and high is... HIGH! A nice tight hotspot, very very bright, and nice tint too. More neutral than stock.
Memory sets in very quickly, it's very handy.
PWM on low and med has an audible whine, but thanks to the very high freq 3.9KHz it's not noticeable to the eye.
Measured Amp: High 1.74A (aestimate 3.48A at the emitter), Med 0.54A, Low 0.05A
Testing in comparison with other lights I had compared with before, the output is higher.
Hotspot was smaller and brighter than HD2010 even before, but now it makes you wonder if "maybe" the 2010 was on med instead of high, so much is the difference!
As expected, it's still below the TN-31 XM-L2, but hotspot size is similar.
Have no instruments for light measurement, but given the Amp draw and the figures for the U3 emitter, the otf lumen output could well be somewhere 1000lm
I'm very happy for these results, and my 7G5 has become a very usable flashlight!
Gone are the days of random level selection and strobe kicking in every now and then.
Now this is a flashlight with great modes, throw and output, going to make me smile when I hit the switch
Note: english is not my own language, so I apologize for any grammar mistake...
