Crelant PT40 driver, how to up the current? Electronic gurus help appreciated :)
I was experimenting with this flashlights, took out genuine driver, used another one + red XP-E2,
beam turned to be complete fail so I am back to genuine driver and XP-G2 now I only need to figure
out if there is a way to increase amperage.
Did some poking around, no those 3 x R240 are not current sense resistors. Third photo: there are some
jumper pads marked with a, b and c, a = no light at all, b = does nothing, modes remain same
as without bridging, c = changes modes to high and low only and that is about all I discovered :/
Led + is by the coil and Led - is by the SS34 diode.
No one? :frowning:
That chip marked LEDA is a QX5241 buck controller, very common chip…
The bank of R240’s IS the right resistors… You’re correct they’re not technically “sense resistors” in the way they operate, they’re more like limit resistors the way they’re on the FET’s source legs. At the end of the day tho, to increase current you need to lower total resistance across that bank.
Thanks for input CK,
I tried to make a short circuit across those resistors with my tweezers yesterday while it was running and nothing happend, not even a 0.1A increase in current draw! I could add something like R200 and measure again.
Unfortunately that’s pretty common with the level of components they use on these things…
Try this instead- leave the resistors as is and swap out the FET’s to some of the known better SOT-23 FET’s we use around here. Either the AO3400 of the IRLM2505.
Just a pointer- never bridge a true sense resistor, it wouldn’t of hurt anything on this driver cause again those are operating as current limiter’s, not current sense resistors but on some buck type drivers shorting the [real] sense resistors is not a good idea, there must be some resistance there to creat a potential difference across a point for it to sense.
Umm, those will not be easy to find…
