I have the V9CS which I think is the first version of this light. I bought it when it first came out and was launched with the XM-L U2.
It’s very much C8 in shape and size, just a little longer due to the extra side switch.
The fit, finish and tactile quality of the light is superb. Better than Convoy. And as far as I can recall is fully current controlled, so no PWM flickering at all, although you can hear it whining.
Personally I don’t like the ramping at all. I find it pretty useless. The V9CS is slow to ramp up or down (I believe the latter models have a faster ramp rate). But I still can’t see the point, as it takes longer than just clicking to get a desired mode.
Also you can’t control the direction of ramp, say for example you are running a “mid” output setting and stopped as it was getting brighter. You now want “low”. You’ll have to click and hold the button, it’ll ramp up brighter and brighter to max, then down, back to where you started before getting dimmer.
Ramping sounds great in discussion and on paper, but the reality is it SUCKS in actual use.
Another plus point, it does go very low. But due to the big SMO reflector I find it is a bit useless in moonlight as it’s still trying to “thow” the light. So you only get a small area of light that isn’t all that useful. A small reflector light with the same output is far more useful for moonlight.
Another thing and I don’t know if it’s the same on the V6CS, but looking at the specs I think it is. The light will run on 8.4v input.
i.e.
1x18650
2xCR123a
2x18350/16340
But the trouble is, it isn’t regulated on a single li-ion. Not that this is a real problem. But output is also less. Basically this light likes more volts. I run mine on 2x18350 IMR’s. But of course runtime is vastly less than 1x18650 lights. Combined with the extra length of the light (it’s too long to fit in a jeans pocket), I find I use my C8’s a lot more.
A shame, as it’s lovely made light and like the forward clicky and momentary. In fact it works best as a single mode, always in high kind of light. But the battery options don’t support this use.
As for throw, well it’ll throw as well as any other light using a SMO reflector of this size and the same LED. So for a given lumen output it’ll throw as well as a C8 does.
I can’t offer up lux or lumen numbers. And obviously mine is not the same light.
1 x 18650 = 1.38 tail cap amp draw
2 x 18350 = 1.17 tail cap amp draw (total as there are two batteries = 2.34amp)
On 2 li-ion it is noticeably brighter and gets hotter.
