Here's the English version:
It looks fairly long for 1 x 26650
yes long but it seen good reflector ,not high price ans many place for heatsink &modding.
I think it’s long because there’s that section with a mechanical (rather than electronic) switch. Kind of like the DSTs used to have.
19.5cm? Jeez. That’s only about 1cm shorter than my SupBeam K50 V2, and about 1.7cm longer than my UniqueFire HS-802.
I understand it has a side switch but that just seems too long for it’s own good.
I’m pretty sure I’ve seen one built here but couldn’t find it, spell it “clone” when you search.
I actually like the look of the light, I would like to see a disassembled pic to see what’s up with the heatsinking as well as know the reflector size (and if its Al of plastic) but I like the overall shape.
I don’t like the looks of those springs on the bottom of the head, if there is a mechanical switch section in the body there (like mag’s) then it should made contact with that with solid points since it doesn’t need to allow constant compression/uncompression from installing/removing batteries.
I’m not gonna be the one to chance it, the light’s not worth it [to me] if it needs a new heatsink and complete rebuild of everything else but if its already a good setup and just needs a driver/emitter swap this could possible be a good cheap host, mag’s throw pretty well, if these do to that’d be great (but it doesn’t look like the reflector can be focused as easy as a magmod).
Thanks for posting these.
