Barkuti
(Barkuti)
17
Goot Super Soldering Flux, you can clearly see the recipe in the above shot. :))
Discontinued, yet the same recipe is available by other brands (and cheaper):
Removes rust from steel super easy, and oxidizes it quite fast when hot. Of course this is no problem at all, I've soldered cells with translucent wraps and when I've left the drop of flux in its entirety over the place remainings permeate under the wrap causing superficial rust marks. Nothing major.
Of course you can spread the flux with your finger, removing any excess like I do in the video. The stuff is itching, beware of skin cuts. ;-)
You already believe in many things, good and bad. To believe, mind programming is required. This can be achieved by inducing an altered state of the mind to tune our brain predominantly into a Theta brain wave. It's like a very relaxed (but conscious) state of the mind where you can access the full power of your mind (and being). By reprogramming our minds virtually anything is possible, however this doesn't means it is an easy thing to achieve, namely for the layman in these matters. Feelings play a key role concerning what one can achieve or not.
Esentially, this is the same stuff masters like Jesus addressed in its day, and is now a powerful movement in, for example, the ThetaHealing Technique (I'm undergoing healing with and really wish to fix my life enough to become a master at it some day).
Sat, 08/31/2019 - 05:38
