Custom 14500 silver hand warmer (it is a flashlight)..
A big thanks to all the modders on this forum who have inspired me to have a go at making a flashlight. After the little red light build I have fallen for the small form factor of AA sized lights and the amount of light that they can generate. The light itself is not finished yet as I have a couple of reflectors on order that have not turned up yet so the one I made is temporary. I wondered around the shed a for few times looking for something suitable to make a torch out of and all the aluminium I had was either to small or way to big, when it hit me literally. I should of been looking up not down. A bent set of Renthall alloy bars of my dirt bike hanging there looking at me everytime I walked in the door. A quick measure and in no time the bends were cut of and I was left with a few bits of straight high tensile (gotta make it sound impressive) aluminium bar. A couple of days part time machining and here it is.
All the finished parts used in the build. The cap screws in the switch retainer have a 2mm thread. Ezarc should recognise the o'rings and rubber switch cap. I have also borrowed the glass lens from the little red flashlight as the lens on order has also not turned up.
Driver is a KD V2 8 7135.
Tailcap switch came from IOS. The lens o'ring sits in its own groove to stop it squashing out.
The end of the battery tube is recessed to clear the chips on the driver. Its made from a piece of plain Jane 3/4 aluminium bar.
Assembled. This light is in no way a miniature AA size flashlight. All the threads are M20x1mm pitch. On a MF Trustfire 14500 it pulls 2.9 amps at the tailcap on high so gets hot quickly. The home made reflector has a very large hot spot and not a lot of throw. Just a wall of light.
LED is an XM-L U2. This shot is low. I love the firefly light at this current, .04 amps.
C8 left and Solarforce L2M right.
The twins Arnie and Danny Devito.
Silver Light. The windmill to the right is 15 meters away. This is what I was saying earlier about this being a wall of light.
P60 XP-G2 for comparison. This will kill the silver light for throw.
My best effort at a white wall shot. Firstly the silver light. There is no hot spot as such.
And secondly the P60 again.
The LiFePO4 batteries turned up along with a couple of 18mm reflectors. One reflector was horrible and the other was a beauty. The reflector was for an XP-G so it was modified for the XM-L, for those interested here's a couple of shots with firstly, (do not compare with any previous shots as I have changed the iso on the camera from 100 to 200 and changed the aperture and shutter speed to suit),
LiFePO4 at 1.4 amps. High. Edit, corrected battery type
And secondly Li-ion at 3 amps. High. Feel free to do a mouse over as this silly old fool still can't work it out.
Thanks again guys. Cheers.
Aw man! That is wicked. Well done man, well done! I love those beefy screws on the tailcap together with the bulky lines and the shining polished alu makes it look soo stylish. Well done and thank you for showing how it is done.
Great work .
This build should inspire ....
The 14500 will not like the 3A for any extended time I suppose, but what a beautiful light it is! And that red copper pill is what I always hope for when buying a flashlight but they never do copper in commercial lights.
Well done!
Thanks all for your positive feedback (sounds like fleabay). djozz, I do have some of these on order and hopefully they will draw the same current output.
http://www.intl-outdoor.com/coolook-aa-14500-rechargeable-lifepo4-batteries-p-571.html?zenid=16c83db665ac2f2fd20f476b2446c278
those cells have too low voltage to drive an amc based driver even with xml imho
very nice light otherwise!
Danged Nice Work!! Folks that haven’t done this from scratch don’t quite understand there is more thought in it than hands on work!! Everyone should get do this at least once… and your build will make them want to! NICE!
Dan.
Very well-done, sir.
(applause)
I just came back to look at the pictures again. Beautiful!
Awesome! Love it. :bigsmile:
Nice work, I like the fat threads on it.
Now you have to buy more handlebars for your next one :stuck_out_tongue:
Very nicely done!
I agree that everyone ought to have the opportunity to do something like this. There should be rental by the hour shops, where someone could go in and make their own. I know in the US it wouldn't happen because of all the liabilities, but it's a shame that there are so many out there with ideas that can't ever be done.
Glad to see you have the ability to get yours done!
...and that you share it here.
I suggest 14500 IMR cells for such load.. and that light is a beauty!
@OL: If you think you guys got a problem with liabilities.. come over to Germany. :P
I may have a set of Pro tapers coming that should be a little larger in diameter.
A photo of the twins, Arnie and Danny Devito has been added to the first post.
Superb work, thanks for sharing.
That is a work of art - well done sir!
Fantastic!
Thank you all for the compliments. You've embarrassed me. Embarassed It will be interesting to see how it performs against the XP-G2 when the reflectors arrive. I was using it last night and like I mentioned earlier with the home made reflector there is just a wall off bright light on high and medium which is .9 amp at the tailcap. If its a good night tonight I will add a couple of fence shots (I fail miserably at taking white wall shots). The reflector angle is 20 degrees machined in a straight line to the LED hole.
MRsDNF,
Wow! That's a cool friggin light, and even better that it's home-made (that's my favorite brand). Really outstanding work. (although you seemed to have had the same issue with the knurling tool as I did in the past)
-Match
