Not really, I would expect led burn out with DTP as well, just a little later, DTP only moves heat faster but if it has nowhere to go, you will still cook the led. that is why I asked if you measured the actual current, not what manufacturer say. I’ve burned many leds, and 700ma on a star alone, regardless what kind, sounds like a disaster to me.
If you plan to build 1000 of anything, do not take anyone’s word, always check and recheck things yourself. many times. manufacturers will tell you what you want to hear, so you place an order, then you end up with 1000 parts you can not use.
Oi, I would not do it that way, a recipe for disaster, when hundreds of customers start calling you and telling no uv light coming out, and you have to either refund, or fix at your own expense. BUT good news it, the design is very easy to fix.
Unless you driving the led with under 50ma or so, you never rely on the star alone, you NEED a heatsink of some kind. at 700ma it is a must.
Use aluminum angle profile or a T bar, cut it up, and put up your star with the led on it, it will come out of your airvent 2, with passive cooling and part of heatsink outside, heat will be dissipated, not build up inside. with that cooling you will not need airvent1 or even air cavity unless you need it for something else. use 1/8 or3/16 thick aluminum profile, or if it has to run for hours non stop use 1/4 inch thick.
Also with a target 10-15 cm away do you really need optics at all?
Only finalize design after building and testing few test samples, only then order 1000s of parts cuz when you design something new, you’ll change a lot of things before you get working device. end product usually does not look like original concept, and it is perfectly normal.
Unfortunately in this case it’s not that simple. But it’s my fault for not showing you how the device looks on the outside.
It’s full of curves and has a streamlined design. Sadly I can’t share it due to possible future issues with obtaining the patent.
I’ve had multiple rounds of prototypes made at significant cost over the past year, so yes I’m definitely trying to nail it before the factory starts manufacturing.
The factory is also responsible for QC, so it’s in their interest to have everything working reliably. They are not UV experts though which is why I’ve turned to the forum for advice.
Like I said I’m abandoning the hopes of running at 700mA and reducing this down to 450mA. I’m still confused though about your experience with killing chips at these lower currents, as even the cheaper chip was able to run for five minutes at 700mA (in a non-enclosed space).
PS- The factory confirmed today that the lM317 is regulating both current and voltage. And there is only one of them! so that is adding to my confusion as well.
