So I’ve got a good one for the flashlight modding veterans on here…I’ve been modifying a FandyFire C8 by installing a red XP-E2 run off a 105C with (4) 7135’s. I know it’s a bit more than the red XP-E2 is rated for but I figure it should handle it with appropriate heat sinking. Anyway, so I finally got everything together like I think I want it, go to try it out, and it’s just not quite as bright as I think it should be. Throws a really tight beam, just not as bright as I expected. So, I thought I’d measure current at the tail to see if the LED is getting everything it should be. Here’s the wierd part…at high I was getting around 0.5A, on medium I was getting 1.5A, and I can’t exactly remember what low was right now, but it doesn’t matter as I know it was right around where it should be. Even crazier thing is, high was actually brighter than medium, even though at the tail it was pulling a full amp less. Also noticed that, when I went from high to medium, it would do a brief flicker at a brightness higher than high before settling to a constant medium brightness. Anybody know what could possibly be going on with this thing or, probably a better question, what I could be doing wrong??
First off, you do know that the original 105C goes from Low to Medium, right? You didn’t mention which star you’ve shorted, but in 3-Mode trim, it’s L-M-H. At least all mine are. If you’re using one of those “new 105C”s, I can’t really help you there.
Second, tighten your switch retaining ring in the tailcap & see if that helps. Or (better still), disassemble the tailcap completely and reassemble it correctly (you’re the best judge of that) and retest. It may not help your present problem as much as I think it will, but you’ll likely find the experience useful someday.
This is just a start. Post back if the switch isn’t the problem. You’re in the right place for the help you need!
Dim
You are pushing the red XP-E too much. I did the same mistake last time. LED will become unstable at high current.
I end up driving my XP-E(700mA) with stock driver and AA instead of 18650. Brightness is almost the same with 105c. Temperature is not a huge issue as current is much lesser than pairing with 105c.
I’m running a red XP-E at 1.4A and it runs fine. I do have it mounted on a copper Noctigon though,
Is your driver grounded well?
Take the pill out and test it while it’s not in the light if it’s doing the same thing check your driver and led leads for solid connections. If it’s not doing the same thing and works fine clean the threads of your light.
any idea of the lumen output here?
I have an S3 on order at Mountain with a red XP-E on a copper Noctigon. Richard said he was going to ‘push’ it a bit … anticipating a bit over 150 lumens.
thanks…
patrick
Red is too different to look at for me to estimate lumens. It’s nice and bright though. I built it in a cheap C8 for a hunter.
Forgot to mention…the emmiter is mounted on Noctigon, lapped to the pill, and attached with Artic Silver epoxy. Maybe I am trying to push too much current through it…I don’t know
Might try to get a Nangj AK-47 3*7135 and see if that works, wonder if it's getting too much power and overdriving the emitter, the rig by freeme looks like a SK98 rig, it has a 20mm driver if I am not mistaken
Definitely would like to see some wall shots from a red emitter
Darn, crazy cheap!
http://www.fasttech.com/product/1574705-cree-xp-e-1w-620-630nm-red-light-led-emitter-on
WarHawk - What’s the difference between the AK-47 and the 105C? I’ve seen the AK-47 mentioned numerous times in the forums. I might just try and remove one 7135 from the 105C and see what happens. I’m using a Tangfire C8 that originally came with a XM-L2 (yeah, pain in the butt to convert the reflector to a XP-C2 size). It has the small aluminum ring that screws down to hold the driver in place and ground it. I had to grind out quite a bit on the inside of the retaining ring to allow clearance for the small cap on the spring side of the 105C board. I guess I might not be getting good ground but I would think it would be enough. Might try and solder the driver to the aluminum pill to see if that helps. I would love to give beamshots once I get the silly thing working right. Also got another emitter de-domed to put in a cheap Ultrafire zoomie to see what it does. Trying to make a hunting light….
That is the emitter(16mm) that I am using. However, I installed it in a SK68 with stock driver(1.36A@High).
Not quite sure what the difference is…investigating…until then
