Hello my dear friends!
Read the story
Look at the pictures and Info (more will be added as confirmed)
Claim your spot
STORY / RULES:
My friend Steven found a nice flashlight made by a chinese flashaholic and posted some pics on Instagram.
He got a lot of PMs where to buy – so he contacted the manufacturer.
And here is what they agreed on:
- The manufacturer will make ONE production run
- price per kit: US$ 109.99
- international sales and logistics via banggood.com
- The run needs minimum 100 units to be started (status will be updated here)
- The manufacturer will limit the total number of produced flashlights to his available supply and capacities
- You can claim your spot by leaving your contact email in the form below
please note: if more people claimed a spot than items are ready to buy i draw those people who get the opportunity to buy - you will get an confirmation email that you are on the list
and another one only when you can buy yours!
Specs of V4+titanium flashlight :
1. 3 LEDs / TIR Lens / 18350
2. stone washed and polished finish available
3. LED: Cree XP-L HI,4000K
4. Package list:
– 18350 cell (Micro USB charge)
– 18650 tube
5. max lumen: 2500lm
6. Mode setting:
-Mode 1: 200lm-1000lm-2500lm, cycle switching, with memory mode, automatic downshift when the battery is insufficient
-Mode 2: 10lm-100lm-500lm, cycle switching, no memory, automatic downshift when the battery is insufficient
-Mode 3: 1000lm-2500lm-Frequency conversion flash, cycle switching, without memory, automatic downshift when the battery is insufficient
-Mode 4: SOS (500lm)-breathing flash (10-500lm, cycle time is 5s)-beacon (200lm, 0.5Hz, 0.3s each time light), cycle switching, without memory, automatic downshift when the battery is insufficient
7. Mode switch
(1)Factory default mode one
(2)When the flashlight is working, Quickly press the switch 10 times, Lights off temporarily, After 2s the light flashes once every 1s,4 times is a group(Repeat two groups) When flashing the first time, press the switch to select the mode 1 as the current mode; When flashing the second time, press the switch to select the mode 2 as the current mode; When flashing the third time, press the switch to select the mode 3 as the current mode; When flashing the fourth time, press the switch to select the mode 4 as the current mode; As light repeat two groups flash, If no action is taken, the previous mode remains unchanged.
8. size:26.5mm91mm
9. weight:95g (no battery)
10. waterproof: IPX8
11. Impact resistance: 1.5m
12. Tritium and Glow Gasket is not included in package.
– 8 pcs 1.5 * 6mm tritium can be installed on the head,
– The tail can be equipped with 12 pcs 1.5 * 6 tritium,
– 2 pcs Glow Gasket can be pasted at tube
more pictures will be added as i receive them!
(please ignore the colored one – for now)
