In another forum, someone laid out a helpful chart of lumen ratings for the Convoy S2+ red covering the versions 7135x3 to 7135x8. I found it helpful because descriptions in online stores don’t usually list the lumen ratings for this light since there are so many different versions.
His numbers were determined this way: “It looks like Convoy specs use LED lumens, so I’ve discounted the LED lumen figures from Cree by an arbitrary 20% for optical losses.” That makes a big difference. For example, the 7135x6, XML2 T6-4C (and T6-3B) goes from 803lm max to 640lm in high mode.
Does that sound like a legitimate way to decide usable lumens? I’m asking, because after all my reading I’ve decided I don’t need something with really high max lumens; I want something with usable lumens from lowest to highest even if I don’t use the high mode all the time. Stores often give (max) lumen ratings, but sometimes they exaggerate, and they may be giving the Cree LED ratings rather than the actual flashlight ratings. Right now the front-runners for me are: Atactical A1, Astrolux S1 , Convoy S2+ 7135x4 (T6-4C). But I’m mostly interested here in the idea of starting with a Cree rating and lowering it 20%.
“Cree lumens” are lumens that the emitter produces as a function of current through the led. If you have a led in a flashlight, you will have losses due to the reflector, the lens, and maybe some losses around the centering ring around the led. Whatever comes out of your flashlight is measurable and is called Out The Front (OTF). I think it’s a rule of thumb that the total loss is about 15, or maybe 20.
ANSI FL1 Standard lumens uses Out The Front lumens.
You can take a look at the Skilhunt H03 here: H03 LED headlamp – LED Headlamp │ Tactical Flashlight
The first picture says “1200 led lumens”. This is the amount of light that the led produces. If you scroll down to the output table, then you see “FL1 Standard”, and the maximum output is 1000 lumens.
This means you have an efficiency of 1000/1200 = 0.83, or a loss of 0.17, or 17%
You know, coming as a non-connoisseur of flashlights to this forum can be hazardous! It used to be easy buying a flashlight. Stop by Walmart or Home Depot, look at ones in my price range, and then think, “This one looks good. Switch feels good. Pretty bright (if I can turn them on).” Now it’s, “How many chips are on this thing? What’s the tint? Can it be modified? Is it throwy or floody?” :laughing: I probably would have been happy with my snazzy Coast Polysteel 250 (312 lumens), $11 on sale at Walmart (except that the twisty zoom is so stiff it can’t be turned with just one hand). Ah, the hazards of knowledge. . . .
Honestly I wouldn’t worry too much about lumen ratings. Just get something close to what you want… 1000 lumens is visually VERY similar to 800 or 1200 lumens. All of those levels would look the same unless you are really really looking for the difference.
For a light to look 2x brighter, you need 4x more lumens.
I’ve read that thing about 4x the lumens for 2x the brightness. I’d like a light that’s a bit brighter than my Coast (312 lm). Does that mean getting one that has 1200 lumens? Ones at that rating have step-down safety built in, so it wouldn’t stay that bright for long anyway. Even the Atactical A1 steps down from turbo to high after five minutes (I’m waiting to find out whether it steps down to medium after that). An Anker rep said their LC90 doesn’t step down, but the lowest setting is about 250 lumens. I’d like something lower.
Thanks again for the responses. I’ll get all the info together on the top options, and then flip a coin.
