Hello, guys! There is good news to tell everyone that I have applied for a special discount for all BLF users. PM me to get a coupon if you are interested.
What I want to recommend to you today is our long thrower K3.
The CYANSKY K3 is a long-range LED flashlight specially designed for tactical uses. Equipped with Luminus latest SFT-40-W LED, the palm-sized K3 can reach a maximum of 600 meters beam distance with 1600 lumens.
The long-range torch is super multifunctional for general lighting, law enforcement, security, searching, rescuing, self-defense, and so on. It comes with a zirconium bezel which can help you easily handle close combat and break windows in emergency situations.
Parameters
- 1*LUMINUS SFT-40-W LED with a lifespan of 50,000 hours.
- Powered by one rechargeable 5000mAh 21700 Li-ion battery and compatible with one 18650 rechargeable Li-ion battery.
- Overheat protection against high surface temperature for better user experience and longer lifespan of the light.
- Tactical tail switch and multifunctional side switch.
- A6061-T6 aviation-grade hard aluminum alloy material shell.
- Premium type HAIII hard-anodized anti-abrasive finish.
- The reflector is made of aluminum alloy, and the surface is vacuum electroplated.
- Toughened ultra-clear glass lens with anti-reflective coating for high light transmission.
- Low-voltage warning.
- Anti-rolling design.
- The maximum output is 1600 lumens.
- The maximum beam distance is 600 meters.
- The maximum runtime is 100 hours.
- Maximum output: 18.5W(3.7V/5A)
- Intelligent memory circuit.
- Concentrating angle: 6 degrees, flooding angle: 70 degrees.
- IP68 waterproof.
- 2 meters impact resistance.
- Workable from –30℃ to 50℃.
- Storage environment: –35℃ to 65℃.
- 133 grams (Without battery)
Let’s see the night lighting effect of K3
