Cyansky K3 review (21700, SFT40, 1600 lumens)
Cyansky is a new and mostly unknown brand of flashlights. K3 is not only one of 1st model for manufacturer, but this is one of the very 1st flashlights with SFT40 LED.
Let`s take a closer look at this a long-range flashlight with a capacious 21700 battery.
➤ Amazon
SPECS
Maximum brightness: 1600 lumens
Maximum range: 600 meters
LED: LUMINUS SFT-40-W LED
Battery: `1*21700 5000 mAh rechargeable Li-ion battery
Unique design: zirconia bezel
Waterproof: IPX8
Impact resistance: 2 meters
Weight: 133g
PACKAGE AND APPEARANCE
Pretty good cardboard box. The design isn’t fancy, but it’s decent.
I warmly welcome adding runtime chart on package.
Kit includes everything you need:
Everything you need is included: the flashlight itself, a capacious 21700 5000mah battery with a built-in type-C charging connector, a cable for it, a holster, a spare tail button and an o-ring, a clip, a manual, a lanyard. The lanyard, by the way, is very fat. I saw this with expensive top-end Fenix ​​flashlights
The holster is good, but nothing more. However, Cyansky H3 has much worse holster.
It takes not that long to charge 21700 battery, just about 3 hours.
The flashlight is by no means compact, but, in general, it has quite average dimensions for a long-range or tactical flashlight powered with 21700 battery. Wurkkos IF22a is shorter, but this is an exception.
Despite the fact that Cyansky is a young brand with a rather strange name (the head of the company decided that cyan - not blue, is the color of the sky), the design of one of their firstborns turned out to be quite good. The flashlight is undoubtly attractive. The only thing that i don’t like is small and flat button.
And once again I am convinced that matte anodizing looks much more attractive than glossy one.
The flashlight can be disassembled into 3 parts
You can position the clip as you like, the flashlight will still work
The flashlight is controlled by a standard pair of tail and side buttons. The tail button direct click one, with a deep move. It supports halve clicks.
The spring in the tail is long, 1 millimeter thick.
Emm…no spring at head? That is really uncool for flashlight that supposed to be gun mounted as well.
The knurling is perfect. Here Cyansky K3 is at the level of well-known expensive brands. The grip is comfortable and secure.
Head is medium sized. That is strange not to see any cooling fins here.
I don`t like this button at all. It is almost flush with the body, there is no contrast.
U need to place clip on the opposite side to quickly locate button.
A frankly impractical solution, given that the manufacturer here emphasizes the tactical component, i.e. lightning fast strobe access.
“Zirconium bezel” What?
this is quite stupid. Bezel is another part of flashlight as we all known. Suppose that manufacturer means “inserts” in bezel.
Reflector is smooth, fairly deep with a bright and long-range SFT40 LED .
Actually, at the time of release, K3 was one of the very first flashlights with this LED. Not the first, as promo pictures states, but one of the first. There were Fenix ​​PD35 v3 and Sofirn IF22 \ Wurkkos FC12
UI
UI is really sooo simple. There is no need to open manual to understand this UI.
I prefer something more flexible, with instant turbo, moonlight, lock mode…But i know that such simple UI is exactly what a lot of regular users prefer.
Off-on by pressing the tail button
Change modes by pressing the side button
Side hold - strobe
Well, UI is matter of taste. And i`ve never was fan of Fenix-style UI.
How Cyansky K3 illiminates
Here is what manufacturer promises
and here is what i measured.
The flashlight has good brightness stabilization, and there are no complaints about runtime as well.
Turbo lasts quite for quite long time.
K3 keeps a stable level of 800-900 lumens when cooled (since this is a flashlight for outdoor use, it means there will always be cooling),. The thermoregulation saw is quite small when working without cooling, only about 5%, the eye will not notice these zigzags.
SFT40 LED is a very interesting LED in terms of light. It is quite bright and has a good throw. SFT40 is not super-bright, and throw is not crasy. But overall combination of both throw and brightness is really good. Osram LEDs with their super-throw has no sidelight at all, for example. Here SFT40 performs better at closer range.
Here is a point i should mention. As a new brand Cyansky might screw up and pick SFT40 with green tint just to get luttle bit more lumens in specs. Intentionally or not, but they used clear cold white LED.
I dont think that CW is good choice for long thrower, but there is simply no choice in case of SFT40. you cannot install 4000 or 5000k version. You can install clear cold white or crappy greenish LED.
OVERALL IMPRESSIONS
Cyansky is a young brand. Did they succeed in releasing a good long-range flashlight? Partly.
So, the flashlight looks great, no worse than models from well-known expensive brands.
21700 battery is good, although it would be rather surprising to see a 18650 model in 2021-2022.
UI… a matter of taste. I don’t like it at all, it’s too primitive for my taste. But I know people who need just that. So i`m trying to be objective.
The brightness of flashlight is fully stabilized, and the thermoregulation saw does not interfere with the use of the flashlight.
Throw is really good, way better then i expected from such optic and LED. Nothing astonishing, but way more than enough for most of needs. I don’t like cold light, but the SFT40 just doesn’t have neutral color temperature options. And Cyansky didn`t screw up by installing nasty greenish LED.
And now it’s time for cons.
The first: no spring at head. This is not a problem in most of situations. But that is uncool for tactical and gun mount-use.
The 2nd: the button, too flush to be quickly located without clip at opposite side.
In the bottom line, I think that Cyansky made a flashlight with good long-range light and simple, simple UI, good appearance and good runtime.
The question is price tag. When it is 80$, there is plenty of other models to choose.
I think that such a price is very bold for a new manufacturer, a flashlight should be perfect to cost 80$ if this is one of your 1st releases.
And K3, with its button and the absence of a spring at the head is not perfect. Though, i have to be objective, some throwers by big and well-known brands cost the same and i found them to be worse then K3.
However, Cyansky K3 is undoubtedly able to impress the average user and, due to the ease of UI is quite suitable for him.
Again. I don’t think the Cyansky K3 is a bad flashlight. I think that it certainly could have been done much better, just by adding a spring to the head and making the button more embossed. Asking 80 bucks for a flashlight in the form in which it is now, and even being an unknown brand, is, in my opinion, a bold decision. It would be worth asking at less to introduce yourself to the buyer, and then raise the price. Or initially roll out a flashlight that is ideal in design and functionality.
I would buy thay light, its gorgeous.
Please let us know what you think when you get yours.
I have 4 Cyansky Lights now. I had one that died. They replaced it with a newer version. I fixed the LED in the broken one. I just got their newest headlight. Anyway, I like the build quality on the lights . They really need to work on the UI and make pricing more competitive.
I am anxious to read what you think when you buy the K3 @zoulas .
