D4V2 firmware
Hello,
I tried to make the hex file myself, but I failed to make some errors every now and then.
I bought a d4v2 flashlight and want to make a new driver for it. the whole project is finished, the hex file foe the microcontroller is missing.
Anduril, emisar d4v2, attiny1634, 1 + 7 + fet, rgb aux.
If not maybe it is possible to change first pwm channel and get 8+fet
Cfg file:
#define RAMP_LENGTH 150
#define PWM1_LEVELS 1,1,2,2,3,3,4,4,5,6,7,8,9,10,12,13,14,15,17,19,20,22,24,26,29,31,34,36,39,42,45,48,51,55,59,62,66,70,75,79,84,89,93,99,104,110,115,121,127,134,140,147,154,161,168,176,184,192,200,209,217,226,236,245,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,0
#define PWM2_LEVELS 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,4,6,8,10,13,15,17,19,22,24,26,29,31,34,37,39,42,45,48,51,54,57,60,64,67,70,74,77,81,85,88,92,96,100,104,108,112,116,121,125,130,134,139,143,148,153,158,163,168,173,179,184,189,195,201,206,212,218,224,230,236,243,249,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,0
#define PWM3_LEVELS 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,8,19,31,43,55,67,79,91,104,117,130,143,157,170,184,198,212,226,240,255
#define MAX_1x7135 65
#define MAX_Nx7135 130
#define HALFSPEED_LEVEL 14
#define QUARTERSPEED_LEVEL 6
Hwdef file:
#define PWM1_PIN PB3 // pin 16, 1x7135 PWM
#define PWM1_LVL OCR1A // OCR1A is the output compare register for PB3
#define PWM2_PIN PB0 // pin 2, 7x7135 PWM
#define PWM2_LVL OCR0A
#define PWM3_PIN PA6 // pin 1, FET PWM
#define PWM3_LVL OCR1B // OCR1B is the output compare register for PB1
I can give for it gerber files to make the same project:
Thanks
What’s the question?
I don’t know how to compile anduril in atmel studio and ask somebody to help me, compile it with 3 outputs (1mc+7amc+fet) or 2 outputs (8amc+fet) on the attiny1634 and send the hex file.
