Now that it gets dark so early, my evening walk feels like a different outing than it did a few weeks ago. I usually take a small pocket light, and I have settled into a habit of using a low, warm glow for the path close by and only reaching for more light when I need to check a crossing or an uneven stretch. I like keeping the light low around other walkers too, since a sudden bright beam feels a bit rude on a quiet street. One thing I am still working out is how to carry it so it is easy to grab with gloves on, without fumbling in a coat pocket. I also try to remember to top up the charge before a longer walk, though I sometimes forget. How do you balance having enough light to feel safe with keeping things simple and comfortable on a dark winter walk?
Depending where you’re at/from…I find that a healthy sized 2AA light functions nicely to address situations like yours. It’s enough size to address alternative uses, can use disposable cells in the event that you need to exercise those alternative uses, and typically provide enough power for a decent amount of light; they’ll last even longer in a lower mode.
To address the gloved hand thing, A thicker light with an easy to index or simple operation is probably best; twisties or single raised/semi-exposed tailswitch. I know this probably won’t get much love here, but I carry a Malkoff MDX3 regularly running a lower voltage dropin. I’m also toying with the idea of getting a “tri-cap”, which exposes the button slightly for easier indexing/access.
If you’re fully invested in whatever light you have, (if you don’t mind sharing), I can recommend that a good pull ring or draw system can help you to index the light, especially for Emisars with side switches. I shared a photo a little while back of a d3aa with a pocket clip rotated off center and a magnetic carabiner ring. The clip is clamped by the tailcap, which locks the sideswitch orientation in my pocket. The carabiner ring allows a pinky draw (not unlike a karambit) which allows my thumb to index the sideswitch with a pretty good amount of consistency. For thicker gloves, I’d probably replace the ring with a larger diameter one.
Another thing I suggest you try, especially if you don’t like pocket clips, is to use a heavy duty retracting badge clip and jury rig it to retract the light directly back into your palm or a set position, or use a magnetic mount to position the light in a known orientation in your pocket/belt.
**OR, the simplest solution would be just to keep the light in hand as you walk, since you’ll probably will have it in hand while walking anyway…
Lotta dual-beam lights with flood and throw, and more.
HS21 and HS42 headlamps (one can be palmed and the other is effectively a right-angle light), as well as the HD02, HD05, -mini, etc. selectable flood, throw, and COB for area lighting.
I’m still waiting to get back my HD02mini that someone “borrowed”, so I can finish reviewing it, but that’s a nifty 14500-powered compact light that does a bunch of stuff.
No idea how long your walks might be, but the HD05 is bigger with a brazillion times more runtime.
Or the HD03 which is super compact at the expense of runtime.
Depends…
For ease of use with either hand in the dark with gloves on you can’t beat a tail switch.
It doesn’t have to be a “small” aa light to have a low mode.
A coat with an external breast pocket or two is certainly one way to easily be able to clip a light into it and be able to access it with either hand.
Something the size of a convoy S2+ should be able to easily be found with a gloved hand in any jacket pocket.
There is no good reason to play with dinky lights that need to be recharged after one or two walks.
Safe is relative. There’s no reason to go out on the street with a light that won’t let you see clearly out near 100 m down the road.
Even if most of the time you just want to dimly light the road around you. It needs to be capable of more.
Please tell us what light you carry on these walks? You talked about reaching for more light at certain times, so do you carry a second light and what model?
Yes this is something to consider. I find trying to locate a side switch with gloves on to be frustrating. I can always quickly locate a tail switch.
I like to carry one of my Convoy M21B lights. You have a wide range of LEDs to chose from so that you can get a beam profile that you like. Battery capacity with the proper cell should be quite enough for even very long walks. I find that the lowest levels, even though not sub-lumen, are low enough for evening urban walks. Light can be aimed at my feet or off to the side so I don’t bother other walkers. The only downside may be the size. But I have no problems fitting those lights into the pockets of any jacket or coat that I have.
You really need a plunger light to be able to find the switch.
Know how many times I was pushing on the lens of my TS10 in the dark?
Mea Culpa. That is partially why I mentioned the M21B… more difficult to confuse the head and tail ends. But even with the TS10 or the FWAA that I have been carrying lately… at least there are only two choices. But neither of those lights is one I would pick for use with gloves on.
Yeah, I lost track of Convoy lights over the years. I used to know the S series backwards and forwards, but that was ages ago. Aside from the OG L2 and L5, that was it. Newer models… just never followed. Can’t even pin down why.
M21B (Convoy Stock Photo)
For something a little more pocketable:
Convoy S21G (Convoy Stock Photo)
But maybe you start running into that “Which end is which” thing that you mentioned.
For jacket/coat carry I like the M21B better.
Yeah, I vaguely remember the shape of the M21B in its original 18650 form. This one’s a 21700?
Same dealy with my L2 that became a L21? Though I woulda sworn my L2s were 26650 (1, but 2 with extension). All I remember for sure was the rough chalky ano that grew permanent fingerprints. Gripped like glue, though.
Yes 21700. I think (??) the equivalent Convoy lights in 18650 would be the M2 and S3/S8.
Which also would likely work well for for the OPs criteria.
The M21B would be a great choice for a tail clicky jacket pocket light, that can pull occasional double duty as a back pocket light.
Lhp73b for sheer output and flood.
Lhp531 for a little more throw.
5000k is good in both.
4000k is a nice warmish option without delving into hi cri territory.
That’s one reason I’m never getting rid of my Cometa. It’s relegated to my dining room at the foot of the stairs, but in a pinch, it goes from a nice wide flood to The Bat Signal™ in a jiffy. Fairly warmish, maybe 5000K?
Might be a good walking light. Lower brightness and floody to see where you’re going, but can crank it up and zoom if you want to see what’s running at you to kill you.
I have mine set to yes moonlight, no memory, 4-5 levels, always start on lowest (in my case, moonlight), so I know I’m never going to blind myself in the middle of the night. But it’s programmable to almost anything.
Convoy has a version, and I think The Jax Man has the Z1?
I don’t really have problems with finding which end to press on in the dark but it’s a matter of consistency and how the light is carried.
Yes if it’s a small double A sized tube light that’s carried loose a pocket then you have no way of knowing which end is which when you grab it. Especially with gloves on. But if you keep it clipped in or on something then you know which end is coming out first when you grab it. Any slightly longer tube light like a convoy S2+ , as long as it is clipped or consistently put in some sort of a pocket in the same manner every time, is not likely to be flip flopping in there so you should know which end is coming out first as long as you put it into that pocket the same way every time.
So the light matters and how you are going to carry it matters. You must find a symbiotic relationship between those two things. And one of those things may dictate or influence the other one. A failure to figure that out is no excuse to only carry an AA light outside after dark on a walk.
More pockets more better.
well, i have my flashlight on a lanyard around my neck.
a necklace, if you will. the flashlight is in the chest pocket of my coat,
but is easy to retrieve when needed. i also wear a hat with lights in the brim.
most of the time only the hat lights are on. the flashlight is for distance.
here is a web image of the brand of hat i wear:
Just a brute doing brutish things, I guess. Me dumb, need fast light, need stick maybe. Light not so light, but work good.
That hat with built-in lights is actually pretty clever! Having both hands free while walking in the dark is a big plus. I usually prefer keeping a flashlight handy too, especially when I need to see something farther away. Looks like you’ve got the perfect setup for those long winter evenings!
Dunno about recent ones, but older ones were powered by coin cells. About as much light as a throwie. And the usual hideous arctic cold white.
Worse, quiescent current drained the cells within a week. So you gotta pop em out and only put em in when actively using the light.
Same like digital calipers and the like. Even when “off”, they eat cells fast.
Whatever Elon tells them to carry ![]()
