I know de-doming is beneficial in terms of throw for torches with reflectors but is it worth it for zoom torches with a lens? For example the one in the link… Page Not Found - Aliexpress.com
Would it be beneficial to de-dome this torch or similar design torches?
Sure
Dedoming helps everywhere you need throw.
OK. I was told a while ago that the dome is essential in zoom lights because it directs light towards the lens… Is this not true?
The dome does direct more light to the lens, and it does increase the luminous flux (lumens) and thus the efficiency (that's why they put it there), but it does not increase throw. Actually removing the dome increases throw (it increases the die's luminance by 'photon recycling' through total inner reflection).
Right. Thanks for the explanation
True, but not “essential”, factored with less light coming out of the LED, the same as with a reflector light, dedoming a lens light also decreases the fraction of that light that comes out the front.
That particular style of light has a relatively long focal length for its size and therefore a small spot, increased throw and reduced output for intermediate focus positions and probably increased output at full flood, compared to a light with similar size front opening and a shorter focal length lens. Dedoming will give yet more throw and yet less total light getting through the lens.
Are you referring to the light in the link I posted? If so, I think I’ll give it a go and see what happens, they’re cheap anyway so no big deal if it doesn’t work out ![]()
Yes, the link at the top of this thread, I have two of that stile, one from the BLF deal alert thread. They have slight differences but are both fairly good quality built. Neither has a meaningful brand name. The lens nearly fills the front of the light, which I like.
