no, they are full of crap and don’t speak/understand english
i didnt press for a full refund even though i could probably get one… i can put these in my tv remote or something, but they wont be used for lights…
as soon as i get my second order im filing another claim as well… if they had any brains they would cancel and refund my other order before it shipped like i requested.
so the AAA’s have between 715-1115 mAh? The text on the battery says 820 mAh, so the results seem a bit strange to me, is there even 1115 mAh in any AAA battery yet?
Someone correct me if I’m wrong, but I believe the stated capacity for these types of batteries is the minimum capacity and that while it could be higher, is guaranteed not to be lower. Seems like they should be more consistent though.
I don’t understand why the fake assumption… as far as I’ve read members are getting 700+ to 1100mAh for the AAAs, and all 2000+mAh for the AAs. I believe those are quite spot on the the Recyko claim?
I’m not even on this deal but are tempted now from these results… those capacity looks good to me.
[The AAA battery label mentions only “TYP 820 mAh”.]
Think “fake” is used to refer to the inconsistency in the charged capacity and the process of charging. The final capacity should be within +–100 mAh for 4x AAA and charging should be finished within 30 min from the first to the 4th. The final charge capacities are far too apart and one final charging was still going on after more than 1 hour from the other 3.
Also ‘Pregulla’ gave a past BLF thread on the GP where the subject line mentions ‘fake’:
Good price on GP Recyko+ 4xAAA at FocalPrice @ 6.18$ [FAKE?]
(And I must admit, I misread Teutate's results as being for AAs instead of AAAs which made the numbers a whole lot more worrying. )
You are right Pulsar13. For AAA cells the results seem pretty good - though a bit more consistency would be nice. But hey, we aren't paying Eneloop prices for these......
I'll reserve judgement until I have mine in hand and tested with my C9000
For cells rated at 820mAH, the overall numbers are OK, though the 715 is lower than I'd like. However, wasn't this the one that came up from 320 the first time? As I said, I'd prefer they were a bit more consistent. (And I also said that I didn't expect Eneloop quality at this price.) Perhaps a few more cycles or even a break-in might be useful.
I'm not having a go at you BLightSam but may I suggest you run a few more cycles on your charger before concluding that they are no good? Even Eneloops improve over the first few cycles. Does your La Crosse have a proper "Break in" or "forming" mode rather than the TEST mode you used previously?
@ Tuetate - I wonder if you would have the time to number the cells and see if there is any difference depending on what bay they are in when charged. I'm not familiar with the "Shan" charger used.
(I suspect that bay 1 of my MAHA C9000 reads /charges a little lower than the other three but I haven't tried to prove this.)
I know testing this way is probably a bit anal/obsessive so feel free to say no. I'll keep waiting for mine.
Tested one ReCyko AA 2050mah Nimh battery, kind of slow with a hobby charger. Got 1718 mah @ 1 amp discharge.
I did notice that when the charger fully loaded the battery at 1 amp the cell voltage was at 1.14v starting, not very impressed with that amount of voltage sag. They might be best suited for low drain devices.
You can see in the graph at some where around the 12 minute mark the cells voltage was at 1.01v loaded.
