Not too bad of a deal for a XM-L emitter and a P60 host body...can almost guarantee the driver is going to suck rocks! But a simple swap with a 2800mA Nanjg 105C 8*7135 and you have a pretty decent little 10W GP throw around budget rig.
I bought a Ultrafire 502B host and a P60 dropin for right at $12-13 from FT, I think they have a pre-built one ready to go for maybe a little more than $10
These are the quintessential throw around beat em up and don't cry about it rigs...just remember to wrap the P60 dropin module to ensure better heat sink capability
Looks like this one already has a Nanjg 105C driver in it, you can add 7135 chips to this to increase the power to the LED, the other one you would need to completely replace the driver
Extra options on the 105C in my mind is worth it, but only 3* chips means it's only pushing 1050A to the emitter, not a whole lot of power
But 99.4% of buyers enjoyed this product! (230 votes) 263 orders (230 out of 260 give good reviews)
Does BLF coupon work to drive that aliexpress one down a bit?
On EBay, I ordered a C8 for about $8.
Their ad said it was a TrustFire, the display had a picture of a KinFire, what was sent was an UltraFire……but what I really got was a CrapFire.
With that cheap P60 flashlights prepare that not only driver is low quality. The pill is most likely made of aluminium (just painted yellow to imitate brass) and is hollow - with an emitter cooking in the air. Not to mention short threads, low build quality, these new cheap ultrafires are much worse then the old ones. Here’s a comparison with older 502B:
I’m not sure about the quality of the host but the driver is the standard Nanjg with 7135s. I also thought aluminium has better heat transfer than the brass. Which is it?
I sent him a private message. I ask quotation for a 4x7135 (6x it’s too much for this host) and neutral XML2.
I’ll wait for reply. Thanks for the hint!
Hey
In this thread UltraFire WF 502B stare i nowe - www.swiatelka.pl you can see how pill looks like in cheap wf-502.
Pill has big hole under the MCPCB and is made from aluminium… LED probably will burn in 5min.
