Save 5% on all Brinyte products by using https://rebrand.ly/brinyte . Discount automatically applied.
https://youtu.be/N1hHYsnUSkI Brinyte PT28 Oathkeeper Compact Tactical Flashlight: 1600 lumens, gold-plated contacts, Cree XHP 35 HD, tactical grip ring.
1PC Brinyte SR88 Rescue Angel w/active cooling White Box 25% off . More information and pics at https://flash-reviews.com/brinyte-sr88-white-box-special/
$586.88 Message me or use the form on the page if you're interested. Thank you.
PRODUCT DESCRIPTION
BRINYTE SR88 Rescue Angel is a super bright and long beam distance flashlight. It utilizes 12pcs CREE LED and alloy aluminum smooth reflector, its max output can reach 12500+1umens and 1300+m beam distance. With the customized silent cooling fan, the flashlight runs safely and efficiently. It uses a battery pack that consists of 8 x 18650 lithium ion batteries. This battery pack provides long runtime and high output and it has a built USB ports that you can use to charge your devices. Plus built-in power indicator of the front side switch and battery pack, SR88 Rescue Angel is an excellent choice for search, rescue, camping, urban/cave exploring, and other outdoor activities.
PRODUCT FEATURE
- Super bright and long beam distance
- Powered by one battery pack which can be an emergency mobile power bank
- Equipped with customized silent cooling fan makes the flashlight cooling in time
- 3 hours fast charging
- lntelligent power indicators. Alloy aluminum reflector with professional optical analysis
- Reverse polarity protection design, to protect from improper battery installatlon
- Regulated power supply maintains constant current output
- Overcharge, overdischarge and over-heat protection
- Aircraft-grade high strength aluminum AL-6061-T6 with premium Type III hard-anodized anti-abrasive finish
