LEDs are placed in output bins, you see them written as U2 or T6, etc.
But tbh, your eye is unlikely to be able to tell the output difference from one bin to another. So I buy purely on tint spec.
Tint is also binned and will have a code like 7A, 3D, etc
Some places will associate a tint with a Kelvin rating. The chart Djozz shows the tint bins and Kelvin ratings. Note that there will be a range of tints for a given Kelvin rating though.
As a rule of thumb, the higher Kelvin emitters put out more lumens, but as I said, usually your eye will not tell this. So tint is paramount IMO.
But you’ll have to figure out (trial & error) what sort of tint you like best. I find anything in the 4000-4500k range is my preference. Although I own warmer and cooler tinted lights as well.
As for buying. I buy most of my LEDs from Int’l Outdoor. Always high quality and usually a good selection.
http://intl-outdoor.com/led-c-107.html
The Noctigon DTP pad is also very good. Although slightly thicker than many aluminium stars. So sometimes makes the reflector a little tighter when putting back together.
Int’l Outdoor is China based, so usually 2-4 weeks shipping.
If you want it sooner try James (a member on here) at 3Tronics.
http://www.3tronics.co.uk/
As he is UK based, very quick shipping.
I have also used Kaidomain, they offer quite a lot of LEDs and many mounted on copper DtP pads too. Specs are a little less precise than Int’l Outdoor, so you won’t know exactly the bin and tint, just the general Kelvin range. But 99% of the time this is fine.
http://www.kaidomain.com/c/227.DIY-Flashlight-LED-Stars
Similar shipping to Int’l Outdoor.
Loads of other places, but these are the ones I tend to use.
I’m not sure on the internals of the Manker in question. But as a norm you can either buy a bare LED and reflow it onto the original star. It’s not mega difficult, but a little fiddly and if you don’t have the right equipment can be more difficult.
Or simply buy a LED pre mounted on a star. And then just swap over the star, which is just two solder joints. Nice and easy. Remember to apply a thin layer of thermal paste to the back of the star.
Where possible buy DtP stars (direct thermal path). As these keep the LED a lot cooler. Also cooper pads tend to out perform the aluminium ones and are normally thicker.
