defective a123 18650 lifepo4?
hello, i bought this item http://www.fasttech.com/products/0/10002801/1208601-a123-systems-18650-lifepo4-1200mah-high-discharge
i ordered 4 pairs ( 8 cells total) of them and after a full charge they return to 3.3v.
i charge them with the opus c3100 and the internal selector switched to 3,6v max.
my fear is that i received an USED cell…… the price is low and is sold AS IS by fsttech. I opened a ticket but they want a video to prove they are defective ….but…… how could i PROVE it?
i have no skills to do a LOAD TEST …. they are supposed to output 60C current ( and it is what i need……using as car jumper) but i suppose that they would not achieve that results in this state.
is it MAYBE normal for a lifepo4 to NOT BE at 3,6v after a full charge? coming from other “standard” lithium at 4,2v i supposed that also lifepo4 should REST for some week or days at 3,6v.
3.3 V — as expected
(I have some of these on order, waiting for them to come in)
Someone’s review there says
They drop from 3.6 V quickly in my experience. I know bigger packs of 4S Lifepo4 start cars, let us know how your 2p pack goes.
That is completely normal. LiFE packs are a different chemistry than lipos and after charging they drop down to 3.3V/cell.
Not defective
http://batteryuniversity.com/learn/article/explaining_lithium_ion_chemistries
but 3.3v should be the nominal voltage…… am i wrong? if charged until 3,6v should keep that voltage for some weeks(not one hour)…. i thought……
no other one experienced the same thing on SINGLE lifepo battery?
Did you read the description on the Fasttech page that I quoted above, from one of the people who bought them?
Seems normal to me, that’s what I would expect from what I’ve read (and I’m waiting on the ones I ordered to show up)
Found this by ’oogle:
Recommends charging at just slightly over 3.3v, saying that 3.6v is fast but degrades the cells quicker.
I’d suggest you edit the title of the thread — yes you put in a question mark, but the answer seems clearly to be — Not.
I have K2 18650 LifePo4’s and they start dropping right away after charge, it’s normal as others have said. These are solar charged daily to 3.65V, if the sun is out. Here, eight hours later they are at 3.26V.
EDIT: Thats with the light on low (approx. 100ma), so battery itself is probably 3.3V.
I have the same cells, although without the A123-mark on them and a lot of other LiFePO4 cells. They all drop in voltage fast to ~3.3V after taking off the charge current. It is completely normal and no defect. You will see the cells holding voltage on insanely high currents, thats, what they are made for.
All six of them have crusty brown-red stuff around the positive end vents — not a whole lot, not obviously wet or changing, but they don’t give me confidence.
I let FT know.
Yes, they’re sold “AS-IS” but I’d expect they’d checked for leakage before sending cells out.
I’ll post back once I hear something.
