Demagnetize tailcap
I found an old thread about demagnetizing the magnets on flashlights and they recommended an AC demagnetizer. Has anyone actually done it? Would it hurt the rest of the light? I want to try it on my Baton 4 Pro.
A changing magnetic field won’t be enough probably. Heating the magnet might work better (start with 100°C). Unfortunately it will likely damage the non-metal parts in the tailcap.
But you are aware that you can’t use the magnetic charging system after demagnetizing the magnet, right?
I know you can’t use the magnetic charger. The Pro version had USB-C charging so I would rather use that anyway.
Heat works well to demagnetize magnets. Use a soldering iron or rework station heat gun.
The heat must be applied directly to the magnet. It won’t work if you heat the outside of the tailcap with the magnet on the inside.
if the magnet is glued, heating it this way might even cause the glue to release so the magnet falls out.
Also for magnets inside the tailcap always remove the tail spring first. Some lights have removable magnets held in by the spring. The base of these springs looks like a triangle.
I would be worried about using heat since the tail switch is near the magnet. I might have to suck it up and keep the magnet
Good point.
With other tailcap lights I recommend disassembling and removing the switch parts before attempting to use heat to demagnetize the magnet.
However, Olights have an additional issue. The charging cable relies on the interaction of both the magnet in the cable with the one in the tail to stay in place. If you demagnetize the one in the tail the charging cable might no longer work.
