Over the years I have purchased many charging devices and battery packs that claimed 2.1A for iPad. None of them worked. Even ones that HJK checked over and agreed they put out 2.1A. It seems there is some kind of Apple code that needs to be recognized. i could never find any that would charge my iPad 1,2 or 3.
I've had an iPad Air 2 for a while now, and decided to plug in these failures one last time. Well. They worked. For some reason my old iPads just showed "not charging", but they are charging my iPad Air 2 perfectly. I'm wondering if Apple just decided to scrap their exclusive code so other 2.1A systems can charge the iPad.
As far as I know apple still use coding in their chargers, my ipad pro only charges at 1A with a samsung 2A or android DCP 1.5A coded charger, but full speed with a apple 2A coded charger. I also had an ipad air that refused to work with my older chargers designed for ipad 2/3, threw error message after couple minutes. Maybe your cable or charging port was damaged?
Also, the new lightning cable is able to handle more current and uses an internal chip that detects coding and voltage between the power & data lines, if these voltage are off it will throw “accessory not supported” error.
iPhones with lightning connector (from iPhone 5) will charge with virtually any Usb port as long as the source voltage is not lower than 4.5V, with the exception that when it is coded DCP it could detect it as a normal computer Usb port and only pull 0.5A. iPhone 6/6S can pull as much as 1.3/1.7A under load but Apple doesn’t publicly show this info and only includes an 1A adapter, in order to reduce battery wear and keep the device cool while charging.
I have done some testing with my YZXstudio power monitor, very handy tool as it can detect the coding of the charger, which normally requires more expensive gear to do so. I have posted a review of this meter under “USB devices” subforum.
apple is the devil… I remember when they put out that update that made me trash a bunch of non branded cables. I try to avoid companies that use these business practices.
From the iPhone 6 onwards, Apple have built in fast charging, they can actually use the same 2.1A as the iPads.
Apple's iPhone 6 and 6 Plus ship with higher capacity batteries that deliver exceptional battery life, but as pointed out by iLounge and MacRumors forum members, the two new iPhone models can also charge significantly faster when used with an iPad charging adapter rather than the smaller adapter included with the iPhones.
According to preliminary tests using a Kill-A-Watt device and OS X system information, the charging profile for the iPhone 6 and the 6 Plus match that of the iPad, allowing them to charge using 2.1A. Unlike earlier iPhone models which would only draw 5W regardless of the charger being used, the new phones are capable of drawing up to 12W, allowing them to charge at a faster rate. Early feedback from owners suggest the larger iPhone 6 Plus can charge fully in approximately two hours from an iPad adapter.
Work gave me a stupid Crapple 6s Plus (I’m an Android guy). It seems to charge fine with anything. Even the $5 lightening cables from Family Dollar. I’ve bought 3 of these things PowerAdd Charge Station They are awesome. The most recent ones I got were 2 for $30 on Fleabay. I’ve got a Kill-A-Watt but tend to use the little $5 USB power meters instead. I find they are great for measuring cable performance. Once you are plugging everything into a 2.0+ Amp charger, your next big stumbling block is too long or just funky/cheap charge cables.
Not entirely true... here are some real world testing numbers using tronsmart 3-port quickcharge capable adapter with Apple 5V 2.4A codification and latest gen lightning cable (the longer one that comes with ipad pro):
i6 screen off/on: 1.3A/1.7A max
i6+ screen off/on: 1.5A/1.8A max
I have a portapow premium usb tester, which was proven by HKJ to be highly precise and an YZXstudio usb power meter, very famous in china for it's precision and functionality, and got about the same numbers with both of them. kill-a-watt devices only measure the input power however the output power is a whole different story, for genuine apple chargers the efficiency is around 80%, eg. an apple 5V 1A adapter pulls 6.5W when the output is exactly 5.06V 0.99A, whitin 0.3% of the spec:
You need one of these bad boys. BESTOPE® Voltage Testers (C-Blue) Buy like 3-4 of them and average them out and keep the one that sucks least. At least that’s what I did I’m seriously jealous of your gear, but I’m keeping the B in Budget.
youll need to argue with almost all of the phone technical sites and tell them they are wrong and you are right, what you've quoted as my words belong to MacRumors. I included the link to the review:
A bunch of “news” sites being wrong? What’s the chances of that?! /s
Only one of them even attempted to measure the charging power, and even that one didn’t know wth they were doing. As Will mentioned, they used a kill-a-watt which can only measure the AC power, before the charger losses and any cable losses. If the efficiency is 80% then their kill-a-watt reading of 12.6 equals 10.08 out. Which perhaps they don’t understand.
No. The phone is not drawing 12W. The charger is drawing that, the phone is drawing a couple watts less.
I think I’d go with Will’s testing with a portapow over a cheap kill-a-watt wielded by a random reporter who seems to lack a complete understanding of phone charging.
And since the max current is determined by the li-ion charger chip in the device, perhaps it’s just that the i6+ chip maxes out at 1.8A. Either it’s set for 1.8 or it’s set for a bit more but has to throttle the current because it can’t dissipate the heat fast enough to do any higher (this feature is standard on charger chips).
I know this thread is a little old but I have a question about the YZX in the picture, which is the ZY1265 that is still available but they have newer models such as the ZY1270, does the ZY1265 offer anything better than some of the newer ones if you know? sometimes an original is better than newer models that change things.
