I see there are 2 version(or bin) of sst-40 led, 10W and 15W, so what is the main difference, i know they are different in color temp( the former is 6500k and the other is 7500k), but is there any difference in output power
Thank you in advance
Per the datasheet, there’s actually 5 bins ((N2,3,4,5 & P2). I didn’t see any power rating but the flux binning structure table show all bins tested up to 5A which implies to me that they’re all rated at 15W. Their color temp starts from 4500K up to 10000K, I don’t know if the warmer temp are available in a top binned leds, hope that helps.
FWIW I don’t know that anyone has seen an SST-40 with a color temp warmer than 6500K.
I see listings on AliExpress claiming 10W. They have excerpts from datasheets that show a max current of 3A. They must be from an early, private draft, because the published datasheet, which is still marked as “preliminary” & doesn’t show any revisions in the change history, says the max current is 5A (and so, 15W nominal).
I’ve purchased multiple SST-40s from such a listing on the HotRED LED Store. I haven’t done careful testing, but I do know that on the 20mm aluminum MCPCB they are sold on, in a smallish light (18650 with a ~30mm reflector) with a decent thermal path, with spring bypasses, a DD FET driver (like a Banggood BLF A6 driver), spring bypasses and a 30Q battery, running them on Turbo, they will eventually go angry blue and/or only operate in undead mode (self-imposed moonlight). Until then, though, it’ll be really bright ![]()
Moved to a DTP copper MCPCB they are much more durable.
Agreed.
I’d love to get my hands on some 4500K SST40.
The output from the 6500K ones is awesome, but they are just too cool for me.
Yeah. I’ve got a bunch of them still, along with a bunch of the 6500K SST-20s. I love the output, and it is a plus that the cool white is clean, not overly blue, but I’m hesitating on doing any more builds with them (beyond finishing the triple SST-40 that I’ve had a few setbacks on).
Has it changed in the past months? Anyone got hands on SST-40 anywhere around 5kK possibly?
I don’t understand why they’re not available anywhere.
I managed to find only: https://eu.mouser.com/ProductDetail/Luminus-Devices/SST-40-WDS-F50-N3501?qs=byeeYqUIh0PGvK6FJWZRAw==
500 pieces is the minimum order tho.
Interesting. Luminus still doesn’t show anything warmer than 6500K for the SST-20.
