Difference between two Kaidomain 86mm reflectors?
I recently discovered the Kaidomain 86mm reflectors while building my Huge Flashlight project. There seem to be two smooth options with the same dimensions, but one is described as “For SST-90 SBT-90 SBT-70”. Is there a difference between the two? I am using the SFT-90 LED.
I’m thinking perhaps they’ve stuffed up both listings, and one has a 7mm hole vs the 19.5mm for the SBT-90 etc.
My guess is that the non-SMO reflector is OP.
For material it states: Aluminum Textured / SMO, OP Reflector
Vs for the SMO it states: Aluminum Textured / SMO Reflector
You could try to contact them for clarification. I’ve had success in the past, but sometimes it took a while.
Hi friends
They are the same. It just duplicate posting for some items that is posted long long ago.
I will keep to adjust it.
Thanks
Thanks all for the responses. I’ve ordered the SMO version. It should do well for my Huge Flashlight project.
Thank you :+1:
