I understand 3 and 5 mode groups. How to swap etc.
What I don’t understand is that when I switch off the light and turn it back on in short time (under 10sec) It will not be in mode that it was turned off but in the next one.
Example, if my words are poorly choosen:
I choose 5 mode group (low,mid,high,strobe,SOS). I’m using a high mode, walking in the woods etc. After some time I turn it off and on quickly. And BAM strobe starts to wreak havoc…
Is that normal? Could it be “tweeked” to not do that and just memorise the last mode it was on?
If not, where’s the BLF sales corner… :~
That sounds like how my S3 and S4 work. Since I just run it in 3 mode group it doesn’t bother me much. I’m thinking of soldering the stars to get rid of the 5 mode group altogether.
It has “on time memory”. It must be on for about 2 or 3 seconds to remember the mode. If you turn it on for a short time, then turned off, it will cycle to the next mode when it is turned on.
That’s how the default Nanjg105C firmware works. It’s there on the sales page too probably.
It has no idea if you switched it off for 0.1s or 10s, so it uses a timeout after which it locks the selected mode to be remembered. Then when you will be switching modes you will have to double click which I dislike and am modding hardware and firmware.
The stars are not used on that '2-group 3/5 mode' version. You cannot lock it into one group or the other using the stars.
Nanjg uses on-time memory (this is a hardware limitation), meaning it can only record the amount of time it has been switched on, and no way to know how long it has been switched off, the MCU is completely powered down and dead to the world as soon as you turn the light off. If it's been on for more than 2 seconds, and you give a brief power cycle, the MCU will not change to the next mode (remember, to the MCU, 1/4 second off is the same as 10 minutes off). If you cycle the power less than 2 seconds after switch-on, it will change modes.
