Can i connect the xm-l2 u3 directly to 18650 battery without driver in beetwen, because i dont like the driver, becuase it have 5 modes and i want just one. I did connect the xm-l t6 directly and works great, even brighter than with driver, but i could risk the xm l t6 because i have few, but i dont want to destroy my xm-l2 u3, because i only have one. Thank you in advance for your help
You need some kind of current limiting, risky with no driver, wastes a LOT of power if a resistor is used.
If the emitter is on a direct thermal path copper star like a SinkPAD or Noctigon, you can. Otherwise it will fry. And you’d be best off using a weaker protected cell, an IMR may be too much for it depending on your heat sink and the thermal capabilities of your host.
With the light being properly set up, direct drive will work, the light will dim as the cell diminishes just like in days gone by.
Just pay special attention to the cells used with it, put the emitter on copper or get one already on copper, and enjoy it! ![]()
You could also swap out the driver with something like the 17mm Qlite, select the proper star for 2 mode operation or find a driver that is single mode only.
XML2 U3 works best with one of those 6000mAh ebay batteries.
Sad, but true. :~
The LED needs good heat sinking to be able to handle direct drive. A copper PCB is your best bet, and until you’re sure the LED has a good thermal path, avoid high drain IMR cells.
Can i do this trick http://www.youtube.com/watch?v=cr6uEMARdZ0
with tmart`s tangsfire c8 xm l2 u3 ??
One option is to use a driver, which gives you access to lower modes and regulated output. But then also install a momentary switch that bypasses the driver to direct drive your light in “turbo” mode.
