by default the D2 ships in Tint Mixing mode… so when you do 2C it turns both on. You can control the mix by using 3H, which will ramp the mix towards one LED or the other.
If you dont want mixing, try changing Misc Config to Channel Toggle. It still uses 3H to switch channels, but it wont mix them:
