My friend ask me a favor to replace his torn rubber switch at tailcap. the problem is I don't know how to remove the switch. it has plastic cover with no hole for tweezer. here's picture (the right one). any help?
many thanks :)
many thanks :)
Have you tried just pushing it out (from the boot side)? I have an A8 clone and couldn’t get the switch out even after removing the retaining ring, and someone said to push the boot really hard, which worked.
you mean this kind of tail actually doesn’t have threads and merely just pressed fit instead of screwed in?
I tried it but not really hard because worry it will break apart if trying harder…
I dislike those press-in tailcaps. Usually they can be pressed out from the boot end, but it requires a lot of pressure. It might break the switch too.
Usually the plastic retainers with no holes are in an unthreaded tail.
encouraged myself and just hammered the switch out, literally…
I used flat surface metal stick and hammered it couple times evenly in both side with plier. and it popped out ![]()
that is the good news. thanks Ohaya and relic! ![]()
the bad news is the tail opening hole is not common…I ordered 14 mm boot cap which has flange about 17 mm but the hole is about 18 mm. so the boot just slides thru the hole. what a waste…
I wonder if you had a washer that had a, say, 16mm hole (or drilled out), could be filed down to fit into the tailcap, and then put the boot through that?
Maybe starting with a 16mm boot would help too. I think they are available at Fasttech, IIRC.
those 14 mm boots are from FT, now I have a dozen of it (mix black, orange, green GTID) sitting around rather useless, LOL.
I will find some nut washer tomorrow. that should do the trick ![]()
These I have, GITD Green 16mm:
http://www.fasttech.com/products/1608/10001928/1138302-glow-in-the-dark-silicone-tailcaps-5-pack
Also available in GITD blue.
I really like the blue. easily match to most host style.
just hoping it able to glow better than in the review.
