Disassembling tail switch of P60
Hi all,
I ran into problem disassembling the tail switch of 502B P60 host. After removing retaining ring, could not pop out the components. Is there some easy way to do this? Want to bake the light to shift colors.(Which I learned about on BLF!)
After you remove the retaining ring, it should just be friction holding it. Try pushing on the button and it should pop out.
Thanks for the quick response! I did, I put it back on the battery tube, inverted it, pushed on it with back of small screwdriver as hard as I could, no dice!
well now the battery tube may be holding it in. Try without the tube. If that doesn’t work, I’m out of ideas.
After removing the retaining ring I drilled two small holes on the plastic just large enough for needle nose pliers. I tryed just pulling on it but, the plastic is pretty soft. I turned it counter-clockwise and pulled it out. I was a bit tight but, turning helps it out.
The way they slap them together quite often there are metal shavings from thread cutting in various odd places that can either make things sticky or cause malfunctions. While you have it open give the whole thing a thorough inspection and cleaning. It didn’t happen when it was made.
Looking at one right now and it’s possible there’s fujik in there. There’s some kind of dried leftover flakes of something that looks like fujik anyway. I’ll try the two hole twisty method.
Clamped a 3” piece of 1/2” dowel in the vice and pushed the button against that while turning and it worked. Pretty tight though and definitely some Fujik in the switch assembly.
