DIY Diffuser
I only like straight wall tube diffusers . Too many materials just throw out way too much glare . I’d rather have light leak out the top because you can always stop that like you’ve done with your flower pot sitting on top . Also consider using diffusion film or a minus green filter before the light even gets into the diffuser .
Something like this in a frosted plastic is probably the best diffuser I’ve ever found
https://www.katom.com/461-SCH400SL.html?utm_source=google&utm_medium=cpc&utm_campaign=[ROI]%20Shopping%20-%20PMax%20-%20Pull%20SKUs&utm_id=17620874820&utm_content=&utm_term=&gad_source=1&gclid=EAIaIQobChMIg_zou6iGiAMVhTcIBR3nEAqVEAQYAiABEgKW_fD_BwE
Try a small styrofoam bowl inverted on top with light shining thru the lid . Something like a shallow container they put extra sauces in at a restaurant.
Tops off of Tide laundry detergent fit the Q8 . The orange is kind of cool /// warm:)
setup:
Cutting the tops of bottles and going from the inside out the top can give you a different size option and the sloping of the bottle shape makes it easier to grab different size lights since it’s tapered . That’s kind of a pro tip
https://test-shop-518.myshopify.com/cdn/shop/products/0011_7350W_c441c9b0-30b8-4848-84f7-6cfdf26ec732.jpg?v=1472573258
Hey Boaz!
That looks good as well!
I will try your setup this weekend.
Bookmarked your messages.
Thank you.
I like it! You’ve added your own flair. Very cool.
Hehe thanks!
I’m using it on the lowest candle mode right now, and it looks really cool. I’ll definitely be using this a lot.
Seemed appropriate … since I realized we were both using the same Sofirn IF25A light .
