Howdy, all!
I was reminded in another thread of an old trick I used, to teach my muscles how to hold a knife for sharpening.
It may be commercially available, but I’ve never even heard of it, so I think this is my own original idea… As always, I appreciate any correction or feedback or comment on the matter!
Practice does not make “Perfect”! Practice only makes permanent.
Only Perfect Practice makes Perfect.
This gave me access to “Perfect Practice”, which helped more than I care to admit.
I’d love to know if any of you guys have seen such a thing, or if you would care to try it (perhaps to teach that recalcitrant relative) and let me know your thoughts about it.
To business: I made a holder for my stone, which would protect it and let me store it. It dawned on me that, if I put a block at the end which had been beveled to the correct degree for the body of the knife, I could lay my blade on the guide every stroke to force my muscles to remember it the correct way.
As a base I picked up a piece of decking board from the scrap pile. It was 5/4” * 6” by however long it was — “long enough”. I cut the guide from a piece of 2”*4” long enough to go all the way across the decking board, then ran it down the table saw at 1/2 the included angle of the bevel I wanted, then relieved the short end to make a wee lip, under which the Stone would slip. I made sure the relief cut fit the stone, of course. I fastened the guide to the base, slipped the stone under the lip (a touching fit, not tight) and used a left-over paint-stirring stick (you could use a Popsicle stick or any thin stock) as a “toe board” to keep the stone under the lip. By lucky happenstance, the base board was ~double the width of my stone so I made sure I could slide it from side to side, to get both hands “in the groove”.
That turned out to be important. Having a full-width guide let me sharpen machetes, Bush Hooks, etc. and sliding the stone from side to side as needed made both my hands “smarter”. It dawns on me, looking at it, that you could put a handle on the bottom, tighten up the stone’s mount, and use it on “the big stuff” at your pleasure…
Anyway, I know a lot of you don’t like a wall of words, so here’s hoping maybe this picture can be as helpful to you as it was to me:
PS: This picture should demonstrate conclusively why I chose Engineering as a career and not Art… ![]()
