I have received the BLF17DD from mtnelectronics.com (Thanks RMM!) but i’m not quite sure how to install the thing. It nicely press-fits into the convoy s3 pill, but when installing a battery and testing, it does not provide power.
I cannot see a way for ground to make it into the driver, as there isn’t an apparent connection between the driver and the pill it’s mooshed into.
So it seems I need to solder the driver into the pill; where should i apply solder? Anywhere along the outer ring? I must have gotten lucky on my convoy s4 build, because i just smashed the driver into that pill and it worked.
Suggestions?
Thanks!
EDIT:
as soon as i posted this, I found this photo in the RMM thread (thanks DBCstm): Should I duplicate this solder here?
I have never gotten a bad unit from MTN. But, I still hook them to a battery to test them out. Then I install.
With that red wire coming out the center Are you sure your battery is making solid contact with the center spring?
Hard to tell from the pic, but what is going on with that wire?
Sometimes the pill sits less deal, so the spring needs to be extended.
Careful pulling on it! I normally solder a extra copper spring on top giving me extra length. This in conjunction of a piece of braided wire for max amps!
hahahaha that’s not my photo, or my driver. I stole that photo from the RMM thread. But considering he’s pulling almost 3000 lumens off an 18350, I would surmise that red wire is working great for him
I am most concerned with the solder joint between the outer edge, just about section labelled “r4” and the pill.
Yes solder the 2 gold traces along the edges of the driver to the pill. If your pill is aluminum, solder a bit of wire to the traces and press fit it into the pill.
The red wire is just like using copper braid to bypass the higher resistance of the spring.
If it's brass, it's easier if you pre-tin the pill. Best to do it while the pill is empty. Put a bit of flux and solder paste on the top and outside rim and heat the pill. If your soldering iron is too low wattage use a heat gun or butane/propane torch on the lowest setting (heat the pill, not the paste directly).
Don't do the inside or you likely won't fit the driver in.
Once it's tinned it's much easier for the soldering iron to bridge.
I quit using solder braid (copper braid) on springs cause it tears after enough spring compression cycles, I prefer using wire like in the pic, much more bendy.
Sometimes a press fit doesn’t quite make ground contact.
If you don’t want to solder the driver to the pill, solder a piece of wire to the inside of the pill, then solder the other end to ground on your driver. On the BLF17DD, I would solder it to the ground leg on the FET.
This is the easiest way if you don’t have a very powerful iron. Ground is guaranteed, and the driver is easier to remove in the future.
It’s the leg closest to the outside edge of the driver. If you have a DMM you can test the connectivity of the leg and the outer ground ring on the edge of the driver.
i like this idea of the wire, because i attempted to do the solder bridge on my other convoy, and it was a mess and didn’t work (or must have cause the light actually works.)
but keeping the pill and the driver into separate solder jobs will likely work much better for me (hopefully.)
