Do you think its worth waiting for the new CREE emitters?
I know there will always be new ones on the horizon, or new bins at least.
But I, like most of you enjoy buying torches, but sadly can’t justify a large disposable income on doing so. To this extent I’ve not really bought much barring the BLF Edition A8 and Mini recently.
However I’d really like something like a XinTD C8, HD2010 and a Sky Ray King among others. But do you think I should wait to see if these are upgraded to XM-L2’s anytime soon?
If I buy them now, I won’t be able to buy them later if/when they do get upgraded - this is my dilemma.
I’m also keen to get an XP-E2 torch, but haven’t yet seen anything. How long do you think it’ll be before the new CREE’s are more available?
If I were you, I would wait.
I'm sure there are going to be tons of XM-L2 and XP-G2 lights coming out in the next few months.
AFA xml2
c8, no
hd2010, maybe
srk, not a bad idea
You could always buy the lights, if you like them, look into upgrading in the future, either do it yourself or get someone to do it, all three you mentioned are easily upgraded with a little attention so why wait.
The hd2010 though, wait to find out if t-mart are still shipping good ones, fasttech etc seem to be shipping ones that totally negate the whole point of the hd2010….
It is definitely hard to hold out. I say wait because at very least when the new versions come out, you can possibly get the ‘old’ ones even cheaper. But it is difficult to say which lights if ever will be upgraded as long as older emitters are still available.
I like the idea of XM-L2 because you will actually get the stated lumens, since they are binned at a real life 85 ºC
Right now I am more interested in good hosts since i expect to be upgrading lights to sinkpad/xm-l2
I have the old XM-L Xeno E03, and just bought the new XM-L2 U2 version. To be honest there's very little if any difference to my eyes. I haven't compared them side by side as far as battery life yet, but I'm thinking there won't be much of a difference there either.
There is a fairly significant difference between the XM-L2 U2 and XM-L U2 versions of the TN30 and TN31.
I must say, all these “names” are so confusing. >.<
Don’t worry chloe, you’ll soon get to know the common phrases.
Xm-l - older Cree emitter, pretty much go to in high output lights at the moment
Xm-l2 - upgraded xm-l
U2 - bin level of Cree emitters, other bins you will see in relation to xm-l are t4/5/6 (lowest brightness upwards, all lower but possibly better tinted than u2) all lower brightness level (on average) to u2, u3 (brighter than u2)
Tn30/31 - thrunite lights, 3*18650 cell powered, single/tripple xm-l/xm-l2.
Emitter wise, there’s also mc-e, Xr-e,xp-e,xp-g,sst-50,sst-90,ssc-p7/z7,nichia 219,mtg-2, just to name a few of the common ones you’ll see, we’re also moving on to “2” grades of these emitters to over simplify things.
You’ll pick it up. :bigsmile:
Thanks, gords! :bigsmile:
No worries, find one of scaru’s posts and click on his Sig line, he had a cell guide and emitter guide in there, real detailed helpful reading. :wink:
I’m not waiting.
I’m buying lights I want now.
… and then swapping in my own XPG2 and XML2 emitters :bigsmile:
Quoting just to put my sig here. ;) Thanks for the recommendation though.
I was just reading them!! Thanks though! :bigsmile:
In months? Hmm, rather years with the speed the emitter gets to the shops :wink:
Get them separately if you want them, get a good light with a cheap emitter like old T6 1A and replace it.
Are there any XPG2 P60 drop ins that are lower than $20? I have seen some expensive ones but none from 'Budget' sources.
The XM-L2 should be nearly universal in budget lights eventually because it is cheaper to produce than the XM-L. But there must be a ton of XM-L LED’s out there for the budget makers and sellers to work through.
The only real advantage for XML2 seems to be the lower VF. Otherwise it is two bins higher than the original.
Xpg2 on the other hand has both the lower Vf and plus it has a higher current. So XPG2 lights, especially with boost or buck circuits have brightness advantage plus better throw in XML currents.
I’m happier than I thought with my XPG2 lights. They throw better and they are brighter with a 1XAA or 1xcr123 as they boost at a lower voltage. XML2 doesn’t look like the same kind of an upgrade for me, though. Maybe for the overclockers.
What about XP-E2, haven’t heard so much about these. Although I’d like to see an sk68 type light with one.
