Does this have a “slide” zoom function, or a “twist/screw” zoom function? If it is a regular “slide” zoom, then you could try removing the pill and head together. Pull the head out to full zoom, and keep pulling outward pressure on it while you slowly turn it to try to catch the pill with friction, and unscrew the pill from the body. Then, you might be able to push out the bezel by pushing the pill from the bottom toward the lens. That’s assuming it is a press fit bezel.
